Sound is very quiet and will change sometimes
    Ok first thing is that I've already been looking for a solution through google and I did come across this:
    I changed it to what the picture shows and my volume is still very quiet. I've also checked if my drivers were up to date and they were. The strange thing is that when I enter a game in League of Legends, the volume will jump louder or quieter but rarely will stay the same.
    The volume level of a maxed out youtube video is:
    I have a hard time hearing people over skype even when its maxed out on volume too. I don't know why its so quiet and why sometimes it spikes louder when I open a game. Anyone have any ideas?
    Still having this problem
    Under "speaker properties" / enhancements, there should be "Loudness Equalization check box, try with that.
    This is all that shows up under enhancements:
    I guess you'll need some proper drivers for sound then. What computer is that ?, check at manufacturer's site for newer drivers.
    I have the Razor Blade Pro
    So, did you try to disable all sound effects ?.
Solved How to change startup sound in Sound & Audio
Hey guys I was just wondering if you know how to change the windows 8.1 startup sound without messing up the metro. Thanks:)
Windows 8.1 and Windows Live Mail does not share system sound on receiving an email. How do I change the sound in Windows Live Mail to another sound? I have tried to change the systemsound for "receiving email" in Windows Control panel, but that does not work. Any ideas?
Greetins all, Is there a way for me to decide where what sound is played? I got it setup now that all communication is played though headset but all other sounds are sent out though the HDMI cable to my sound system. I know some games and application allow me to select under options...
Is it possible to change the alert sound?
Solved Sound is extremely quiet? in Sound & Audio
So I am wearing headphones, they're plugged into a 3.5 mm speaker. This speaker is plugged into my computer's motherboard. I can hear sound, but it's extremely quiet. My speakers are maxed out. Windows 8 sound is 100%. Youtube video is at 100%. I honestly don't know how to update my...
Is there a way to swap left and right channels ? I couldn't find a way in my titanium x-fi sound card settings and software . Thanks.
Hi, I was wondering if it would be possible to either change the speaker settings (switch between stereo, 5.1 etc.) or, preferably, sound balance directly in the registry. Until now, I've only been able to find the key for the speaker settings: However, the changes only go into effect for...
