Sound Popping/Crackling
  1. #21
    I connected both mobo connections to psu and im not using graphic card to repair this. I also used another exact same psu from my bro's computer and same result it did not boot. I don't think it's CPU since Prime95 did not display any errors. So I'm guessing mobo? It's kinda weird.
    EDIT: Yeah it's not my PSU for sure.
  2. #22
    So basically I am going to buy a new mobo and send this one for warranty. But could it be something else? such as the ram ?
    I tested the CPU in a different computer and it worked.
  3. #23
    So I bought a new mobo, now my computer boots. But to my horror the crackling is still there. Confused...
  4. #24
    Did you do a complete new install with the new motherboard?
    Your sound issue, although others have had the problem, seems to be more unique to your installation. You have changed the motherboard and still have the problem. It now goes back to application software or some other hardware attached device, or even something external to the PC. Does this do it on ANY sound? or is it only on certain applications such as the COD? If play a commercial audio CD do you get the noise?
  5. #25
    This is crazy. I can even hear it a tiny bit on other computers.
    I hear it pretty much when a windows sound or little sounds starts or ends. I also hear it at loud frequencies when people are loud on Ventrilo.
    Basically, I spam the windows sound volume adjuster and it pops.
    Way more than my friends computer.
    And yes I have made a fresh install + tried another windows 8 ssd from another case.
    I also tried different mouse/keyboard and different cpu+psu.
    I basically made a different computer and the problem occurred.
    When I play music it does sound awesome with my xonar dx + mmx 300
    The new Sabertooth mobo is not micro so I'm going to have to get a new case but I'm out of cash and I got fired. :S
Page 3 of 3 FirstFirst 123
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
Recently I started noticing popping sounds at multiple frequencies (mostly higher frequencies) when playing audio. I don't know what caused it, but this is what I already tried: Using a different audio port. Updating drivers. Updating BIOS. Disabled all unused sound ports. Installed...
Hi all, I have read quite many posts so far regarding this issue in Windows 8. It Looks like they have overlooked the Sound skipping problem during playback on different programs and codecs. Whenever one uses Media Player, Spotify or any other audio programs the Sound skipps and crackles. It comes...
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
So I just installed Windows 8 and decided to play some music, found out that my DPC Lat is huge and I did try disabling some things such as audio drivers LAN drivers etc. Still didn't solve the problem so I'm at a loss at what I'm supposed to do now. Maybe I skipped over certain parts which I...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
