Sound Popping/Crackling
  1. #11
    If you've updated the Realtek driver from Realtek, uninstall it and try using the driver on the ASUS site.
  2. #12
    The Video drivers was one of my first noted potential causes.
    Have you updated the drivers and did it fix it?
  3. #13
    The problem isn't behind the audio drivers as the popping occurs with and without the Realtek drivers. It also still happens when I install an actual soundcard. Nvidia graphics isn't the problem since I stripped (and fresh installed windows) my case from everything but CPU+ssd+ram and the popping is still there.
    This is super fustrating. I have been trying to fix it during the last 12hours and right now I am checking all the cables inside the case.
  4. #14
    Go to your Playback devices, Speakers, Properties, Enhancements, and make sure everything on the page is unchecked, and then check the option to disable all effects.
  5. #15
    I already tried that like 25 times XD. Like I said, the problem isn't behind the audio.
  6. #16
    I am starting to think it is the power supply, I can't even get the computer on!
  7. #17
    All right, so my computer isn't turning on anymore. I am guessing (and hoping) this has to do with the popping. The power supply is not faulty as I have tried another one and it did not turn on. Is there a way to determine if my motherboard is faulty? The 5volt LED goes on but nothing happens when I press the on/off button of the case (I have also tried the screwdriver on mobo method).
  8. #18
    Did you try jumping pin 14 (green) to a black ground wire on the 24 pin power connector? That should turn on the power supply and if that works, either something wrong with the front panel power switch, its not connected properly or a motherboard problem.
  9. #19
    I'll try this in a bit. So if it's not the power supply and the power switch, is it the motherboard for sure?
  10. #20
    Did you connect both power supply connections to the motherboard? The 24 pin and the 4 (or 8) pin power connectors? and the PCIe power connection to the video card?
    There can be other possibilities, such as a bad CPU, but if the power supply turns on by jumpering pin 14 to ground and the PC works, it only leaves the power switch (and connection to the motherboard) and the logic on the motherboard.
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
Recently I started noticing popping sounds at multiple frequencies (mostly higher frequencies) when playing audio. I don't know what caused it, but this is what I already tried: Using a different audio port. Updating drivers. Updating BIOS. Disabled all unused sound ports. Installed...
Hi all, I have read quite many posts so far regarding this issue in Windows 8. It Looks like they have overlooked the Sound skipping problem during playback on different programs and codecs. Whenever one uses Media Player, Spotify or any other audio programs the Sound skipps and crackles. It comes...
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
So I just installed Windows 8 and decided to play some music, found out that my DPC Lat is huge and I did try disabling some things such as audio drivers LAN drivers etc. Still didn't solve the problem so I'm at a loss at what I'm supposed to do now. Maybe I skipped over certain parts which I...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
