any way to make volume louder when streaming netflix ?
    Hi all when using my computer and streaming netflix, i generally use my HD tv as my video card has audio built in over HDMI and i use it to stream movies to my HD tv ,with netflix app for windows 8. but on some movies the volume is totally Low and i have to crank my tv to here the voice leaving me with very loud music when it comes on. is there a solution to fixing this? i make my TV volume default when i watch netflix. IF anyone has a solution as to how to make it louder would be awesome. I have seen this thing called loudness equalization under enhancements on the HDMI audio would that do it or would it make more noise then do any good?.
    Alienware x51 with windows 8 pro and media center.
    PNY GTX 660TI video card.
    If need any more info let me know.
    anybody someone has had to have the same issue?
    Hi there. I've noticed this with some movies also. Sorry I don't have a fix, but waiting for an answer also. Really it's a Netflix problem. They should all stream at the same volume.
    i totally agree i don't know if enabling that loudness equalization would work or not waiting for feed back before i do it.
    so anyone have a clue on this ????
    Win 8 64-bit
    Quote Originally Posted by TonyB View Post
    I turn Loudness Equalization on when installing the OS and leave it on all the time. I watch quite a lot of video's on the net and find the sound levels are generally all over the place, some being loud, others being quiet. With Loudness Equalization on, it means the sound level I set is much more stable, so I don't have to keep adjusting the volume levels all the time (and if I do, it's not such a wide range). For me I get on well with it, but the best thing for you to do is try it and see how you get on with it.
    The latest Patch Tuesday updates seem to reset this setting to off for some reason and I really noticed it was off. I thought my amp was packing up as the sound levels were all over the place and driving me crazy.
    Control Panel > Sound > Playback > Speakers > Properties > Enhancements
    cool i turned it on and wow it dose make a big sound difference
I installed some software and didn't make it, 'admin', so now every time I start it, it asks for permission to allow it to modify W8.1 My question; Is there a way to change it now, after it's already installed?
Solved Netflix App in Software and Apps
The Netflix App for Windows 8 is now available but it doesn't work on either of my W8 installs. When I launch it the ping pong balls go in circles forever, has it actually worked for anyone? Some of the reviews have complained about the same issues but it seems to work for most people, has 4 out...
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Make Volume Control On Top in Sound & Audio
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Previously when I was using Windows 7, the system restore points were created automatically whenever I installed a new SW or made other similar system change. But it seems not the case in Win 8 any more. I am a SW developer. Although I normally test our SW on virtual machines, but some other...
Netflix Help in Software and Apps
Hey, I recently bought a windows 8 pc and did all the windows update, yesterday night. Now the Netflix app gives me this error when I try to play a show: 10462
