Microphone
    Microphone
    So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP
    Mic When its pluged in while im talking
    Inbuilt Mic on my laptop while talking
    WHY WON'T IT WORK
    Windows 8 Pro
    What does it show under 'recording devices' in 'sound' under the control panel ?
    It says
    Quote Originally Posted by Wullail View Post
    It says Th options i can change are
    Windows deafult (Modified)
    Save As
    Delete
    And there are a bunch of options under but i couldn't name all of em
    Harrisonburg, Va.
    Can you provide a screen shot ?
    Quote Originally Posted by David Bailey View Post
    Done
    How about the drivers for sound ? Can you get them from MB manufacturer ? MS drivers are just basic ones and lack programs for fine adjustments.
    This Is what i don't get look at the screen shots up th last 2
    Harrisonburg, Va.
    Quote Originally Posted by SparkySpink View Post
    Done
    Where are the screen shots ?
    I do not see any.
    Done
    I do not see any.
    At the top of my post
    Harrisonburg, Va.
    Try highlighting the microphone & set as default & apply & OK.
    Then try the configure button.
Page 1 of 4 123 ... LastLast
Microphone
Microphone not working in Sound & Audio
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
I have two laptops running windows 8, Asus AO756-2626 and HP dm4-3099se. Internal mic works on both. I have two computer mics and one professional type that needs an adapter for the jack. When I insert either mics, nothing happens on either laptops. The external mic in the sound settings is grayed...
Hyper V and microphone in Virtualization
HI GUYS! Just wondering if any of you encountered the same problem that i have with my microphone after activating Hyper V.. Basically it stopped working and only produced static sounds. Microphone connected by a jack btw..If I turned off Hyper V, mic start working again.
Microphone volume very low in Sound & Audio
Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix. I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work. 23415 I've read that you have to go to...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
8 microphone in Sound & Audio
microphone not working
