Solved Microphone
SparkySpink
So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP :(
Mic When its pluged in while im talking
Inbuilt Mic on my laptop while talking
WHY WON'T IT WORK
What does it show under 'recording devices' in 'sound' under the control panel ?
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
Can you provide a screen shot ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
How about the drivers for sound ? Can you get them from MB manufacturer ? MS drivers are just basic ones and lack programs for fine adjustments.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Try highlighting the microphone & set as default & apply & OK.
Then try the configure button.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
If you have Realtek sound chip "64bit_Vista_Win7_Win8_R271" driver works just fine with a lot of features more than basic MS ones.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Click the configure button.
Follow the instructions on setting up your microphone.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
You Know im getting really annoyed and you tell me it's should be working fine WELL if you hadn't noticed i did this for someone to help me not to tell me something that's not true :/ I made a complaint it not working fine Ok SO :mad:
I followed the tutorial and says to check if mic is muted on the headset so i did and it wasn't then it says to talk into the right mic even though i am! It never changed anything and im getting so :mad: Please Help meh
Looking at one of your pictures , the Realtek High Definition Audio , the bar on the right is showing full green , that is indicating that the microphone port is receiving a signal at max 'volume' , is it ALWAYS showing that even when the microphone isn't plugged in?
I never did ask , is it USB or a jack type ?
Under configure , what does it show on the levels tab?
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
That is when my mic isn't pluged in ,but my inbuilt mic is on im talking while i took the screen shot. (Laptop)
but when my mic on my headset is pluged in it says the mic is there but never picks any sound it it's not the mic because it works perfectly on my dad's laptop so there is something in the settings :/ and i can't find what it says the mic is there but it dosn't take any sound at all im speaking in both screen shots look at the top again and look at those 2 pictures the last 2
