Microphone
  1. #21
    Harrisonburg, Va.
    If it is a USB connection, try another USB port.
    That happened to me.
    I had it plugged in the back of the computer & my headset wouldn't work.
    I plugged it in the front USB port & it started working.
  2. #22
    Harrisonburg, Va.
    Have you tried what is in the picture ?
    I'm trying to help.
    Please don't get angry if my suggestions don't help.
  3. #23
    Windows 8 Pro
    Quote Originally Posted by SparkySpink View Post
    That is when my mic isn't pluged in ,but my inbuilt mic is on im talking while i took the screen shot. (Laptop)
    but when my mic on my headset is pluged in it says the mic is there but never picks any sound it it's not the mic because it works perfectly on my dad's laptop so there is something in the settings :/ and i can't find what it says the mic is there but it dosn't take any sound at all im speaking in both screen shots look at the top again and look at those 2 pictures the last 2
    We can't help without the correct info , you haven't answered all the questions , is it USB or jack type? , if it wasn't plugged in when you took the screenshots ,we would have no idea what the problem might be.
  4. #24
    It's a Jack Type
  5. #25
    Quote Originally Posted by David Bailey View Post
    I'm trying to help.
    Yea i have Tried that :/
  6. #26
    Harrisonburg, Va.
  7. #27
    bump
  8. #28
    Solved by reinstalling reltek Or something like that xD So yeah it works :P
  9. #29
    Hate to tell you, "I told you so" but look at the posts #12 and #15.
  10. #30
    xD Sorry For not Listening Shove it in meh face i'm just happy it works :P
Page 3 of 4 FirstFirst 1234 LastLast
Microphone
Microphone not working in Sound & Audio
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
I have two laptops running windows 8, Asus AO756-2626 and HP dm4-3099se. Internal mic works on both. I have two computer mics and one professional type that needs an adapter for the jack. When I insert either mics, nothing happens on either laptops. The external mic in the sound settings is grayed...
Hyper V and microphone in Virtualization
HI GUYS! Just wondering if any of you encountered the same problem that i have with my microphone after activating Hyper V.. Basically it stopped working and only produced static sounds. Microphone connected by a jack btw..If I turned off Hyper V, mic start working again.
Microphone volume very low in Sound & Audio
Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix. I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work. 23415 I've read that you have to go to...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
8 microphone in Sound & Audio
microphone not working
