Microphone
  1. #11
    Quote Originally Posted by David Bailey View Post
    Attachment 26075
    Try highlighting the microphone & set as default & apply & OK.
    Then try the configure button.
    Ok i set it as deafult but it still dosn't work :/
  2. #12
    If you have Realtek sound chip "64bit_Vista_Win7_Win8_R271" driver works just fine with a lot of features more than basic MS ones.
  3. #13
    Harrisonburg, Va.
    Click the configure button.
    Follow the instructions on setting up your microphone.
  4. #14
    Did that it still dosn't work WHY¬!!!!!
  5. #15
    You Know im getting really annoyed and you tell me it's should be working fine WELL if you hadn't noticed i did this for someone to help me not to tell me something that's not true :/ I made a complaint it not working fine Ok SO
  6. #16
    I followed the tutorial and says to check if mic is muted on the headset so i did and it wasn't then it says to talk into the right mic even though i am! It never changed anything and im getting so Please Help meh
  7. #17
    Windows 8 Pro
    Looking at one of your pictures , the Realtek High Definition Audio , the bar on the right is showing full green , that is indicating that the microphone port is receiving a signal at max 'volume' , is it ALWAYS showing that even when the microphone isn't plugged in?
    I never did ask , is it USB or a jack type ?
    Under configure , what does it show on the levels tab?
  8. #18
    That is when my mic isn't pluged in ,but my inbuilt mic is on im talking while i took the screen shot. (Laptop)
    but when my mic on my headset is pluged in it says the mic is there but never picks any sound it it's not the mic because it works perfectly on my dad's laptop so there is something in the settings :/ and i can't find what it says the mic is there but it dosn't take any sound at all im speaking in both screen shots look at the top again and look at those 2 pictures the last 2
  9. #19
    bump
  10. #20
    bump
Page 2 of 4 FirstFirst 1234 LastLast
Microphone
Microphone not working in Sound & Audio
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
I have two laptops running windows 8, Asus AO756-2626 and HP dm4-3099se. Internal mic works on both. I have two computer mics and one professional type that needs an adapter for the jack. When I insert either mics, nothing happens on either laptops. The external mic in the sound settings is grayed...
Hyper V and microphone in Virtualization
HI GUYS! Just wondering if any of you encountered the same problem that i have with my microphone after activating Hyper V.. Basically it stopped working and only produced static sounds. Microphone connected by a jack btw..If I turned off Hyper V, mic start working again.
Microphone volume very low in Sound & Audio
Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix. I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work. 23415 I've read that you have to go to...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
8 microphone in Sound & Audio
microphone not working
