Sound stutters when streaming video or audio online.
    So here's my problem
    When I watch YouTube videos I get random stutters where the sound skips. The image doesn't seem to freeze though, just the sound
    I also get issues with the sound streaming music online, where it pauses for a second and stutters even though it's not buffering.
    When this happens, NT Kernel & System shoots up in task manager and uses more CPU than the browser. This by the way happens in every browser, IE, Chrome or Firefox.
    It doesn't happen when playing music in iTunes or watching videos from my hard drive.
    That being said I'm not posting about a buffering type stutter, I am aware of that and this is not it. This is like basically suddenly the computer has a big spike in memory or cpu usage and the video/sound clip stutters for a sec. But it happens often enough to be very annoying. In a 15 min YouTube clip it happened 10 times.
    I have reinstalled my IDT High Definition Codec and my Intel HD Graphics 4000 driver, but still the problem persists.
    Any thoughts of what I can do?
    Windows 8 Pro Windows 8.1 Preview
    Try this test: Start a Youtube video and immediately hit the pause button. Watch the movement of the red progress bar until it fully loads the video. This obviously eliminates any buffering issues if the problem is still there when you try to play the video this way. You might also want to do a speed test on you internet connection. Here are my results:
    Now, I know you are convinced that it is absolutely not a buffering issue and you have done nice testing to that end; however, I would still try the tests as described above. Good luck.
    Thanks for replying!
    Well, YouTube no longer fully loads the video, for me anyway. It loads a few minutes ahead but not the whole thing.
    Also when buffering, YouTube simply pauses and then it starts again later, this is an audio stutter like when the reception is bad or the device has a hiccup of some sort, the sound is chopped up and repeated for a second or two.
    My speed is 11 MBps download and 1.46 Mbps upload.
    Would you like to provide a test link so I can see if mine works?
    Just found this solution that appears to be a direct match to your latest reported condition if using Firefox:
    [Solved] Why YouTube Videos are not Buffering Fully when Paused?
    I was using Chrome.
    I don't mean to be annoying but I have both a desktop and a laptop running Win 8 on the same network.
    The desktop has no issues, while the laptop does.
    The laptop also has these issues on all networks, I was on wifi at Coffee Bean and it still had the issue.
    Also the spike in Kernel activity in Task Manager just at the time when the sound stutters can't be coincidental.
    I've read up and it seems one of the drivers in my laptop is doing this but I can't figure out how to find out which one.
    Also, as I stated before, the issue is also present streaming music such as SoundCloud or Pandora.
    It's not a speed issue for sure, but it might actually be an internet driver? Is there a driver specifically for streaming media?
    Quote Originally Posted by cman22 View Post
    I was using Chrome.
    Hi cman22,
    You could try clearing the cache in Chrome as well. However, I feel at this point that you are not open to any new suggestions. Specifically, I asked you for a link, I provided a fix for Firefox because you said it happens on all 3 browsers, so I'm almost afraid to try and suggest anything new at this point because you are drawing your own conclusions as to what will fix it and what will not. Anyway, I will tell you that I think you are on the wrong track. There is no such thing as an internet driver; per se and there is no specific driver for streaming media (that I am aware of). So, I wish you the best of luck in getting your issue resolved; however, I have come to the conclusion that my suggestions cannot help you. Good luck.
    Cheers!
    I'm sorry but I just don't want to waste your time. It's every single YouTube video I play, every Netflix thing that I play, every song on Pandora, etc. So a link is useless. Here's the most recent one:
    Abraham Hicks~ You can be happy under any and all conditions - YouTube
    I'll try the cache suggestion and see how I can do it for all three browsers since I use them all at different times.
    Unfortunately, you are convinced that it is not a buffering issue and I am totally convinced that it is (until proven otherwise). Moreover, you didn't really provide all of the particulars until your last post when you said it works on my desktop but not my laptop and the wi-fi was added in at tha point as well. So, here's something you can try. Take your laptop and plug it into your router using an ethernet cable, clear Firefox cache (you said you have all 3 browsers; yes?), retest.
    Ok I just did it exactly like the post said, cleared cache, cleared cookies, put cache at 350. The YouTube video still doesn't load all the way, only a little bit ahead.
    I plugged the laptop via ethernet cable and it didn't change anything.
Page 1 of 2 12 LastLast
Hello, Got a new machine, and installed it fresh windows 8.0 -> 8.1 download/upgraded. I've done what I felt were the basics. Ensured all drivers to knowledge are good, performed work on it. When I seem to be playing games in fullscreen mode, being captured to a streaming software that...
Recently, I have gotten an ASUS notebook as a gift and I've noticed that there is one big issue with it. Whenever I stream music from Spotify or watch a movie on Netflix, the audio begins to create a crackling static noise. The issue with the stuttering is whenever I have something playing in the...
Streaming video in General Support
I'm trying to stream TV program videos available from my TV provider on my W8 laptop (Firefox from the desktop). I get a black screen and no audio. On my W7 desktop it works flawlessly. Can anyone help me out?
Video Stutters in General Support
hello, random stutters appears when playing video file and whenever i move the mouse it just fast forwards and will be sync to audio, and when i leave it again, after a few minutes it will be back.. CPU: i7 3770k RAM: 16GB GPU: Nvidia GTX 670 thanks in advance, been trying to find a way to...
I'm using a x86(32 bit) Tablet PC. It has installed both Video and Audio drivers. Both, before and after installing these drivers when watching VIDEO(ie Video App), or even using Media Player, it seems that Video and Audio are not insync. Why? Any guidance on this matter is appreciated.
