Sound stutters when streaming video or audio online.
  1. #11
    Windows 8 Pro Windows 8.1 Preview
    OK; good! Now we're on the right track anyway! Here are some more question:
    How much RAM do you have installed on your laptop?
    How much free RAM is available in the Task manager view?
    I'm starting to believe those spikes you are seeing are being caused by the exhaustion of free RAM and the laptop is starting to page to your hard drive. That could certainly be an issue.
  2. #12
    One step ahead. Taking a dinner break:
    Go into task manager and disable all startup programs. Reboot and retest.
    If fixed, start re-enabling programs (one at a time) until problem returns.
    If no help re-enable startup programs.
  3. #13
    Quote Originally Posted by JustATest View Post
    8GB RAM installed
    3.4GB being used (43%)
    I'll go do the startup suggestion now.
  4. #14
    Ok I'm so glad you didn't give up on me! So after disabling all startup processes, the problem is gone. Now for the painstaking process of turning them back on one by one
  5. #15
    Hooray! Hip-hip hooray! Good for you. Please come back and let us know the final outcome. Glad I could help.
  6. #16
    So far Skydrive was definitely a culprit.
    Will see if there are others.
    Skydrive is so full of bugs btw. I wanted to use it with Win 8 but it's awful.
    Uninstalling it for sure.
  7. #17
    Actually it looks like HP CoolSense might be a culprit too...
  8. #18
    Win 8.1
    I know this thread has been quiet for a while, but I figure I'd add on, since it was helpful in solving my issue.
    I had the audio stuttering issue described, and seem to have plenty of bandwidth, memory, CPU, etc. My ISP had recently been bought out and so I was ready to swear that it was a network issue (to the point that I called them; upside is that they increased my capacity just to shut me up), but it was the Citrix URL redirctor service.
    So, I heartily endorse the advice given here: eliminate startup services to find the culprit. Thanks all!
  9. #19
    MY SOLUTION:
    I can confirm that changing the Default Format option alleviated the issue in my case but has not solved it completely. I'm using Windows 8.1, Realtek onboard sound and drivers. It appears that setting the highest available format quality results in least frequent stuttering, however in my case, at the below cited selected format, the stuttering is still present at times.
    Go: Control Panel > Sound > Playback > Speakers (or your preferred sound output device) > Properties > Advanced > Here change Default Format to: 24 bit 192000 Hz (Studio Quality) > Click Apply
    New information: Choosing a lower quality Default Format - 16 bit 48000 Hz (DVD Quality) has solved the issue completely. If you are an audiophile or get a compulsive nagging sense of unease when you feel things aren't perfect, this solution might not be for you. I however am enjoying it.
Page 2 of 2 FirstFirst 12
Hello, Got a new machine, and installed it fresh windows 8.0 -> 8.1 download/upgraded. I've done what I felt were the basics. Ensured all drivers to knowledge are good, performed work on it. When I seem to be playing games in fullscreen mode, being captured to a streaming software that...
Recently, I have gotten an ASUS notebook as a gift and I've noticed that there is one big issue with it. Whenever I stream music from Spotify or watch a movie on Netflix, the audio begins to create a crackling static noise. The issue with the stuttering is whenever I have something playing in the...
Streaming video in General Support
I'm trying to stream TV program videos available from my TV provider on my W8 laptop (Firefox from the desktop). I get a black screen and no audio. On my W7 desktop it works flawlessly. Can anyone help me out?
Video Stutters in General Support
hello, random stutters appears when playing video file and whenever i move the mouse it just fast forwards and will be sync to audio, and when i leave it again, after a few minutes it will be back.. CPU: i7 3770k RAM: 16GB GPU: Nvidia GTX 670 thanks in advance, been trying to find a way to...
I'm using a x86(32 bit) Tablet PC. It has installed both Video and Audio drivers. Both, before and after installing these drivers when watching VIDEO(ie Video App), or even using Media Player, it seems that Video and Audio are not insync. Why? Any guidance on this matter is appreciated.
