VIA HD Vdeck "We Can't Find HD Audio Device" Error
    Windows 8.1 Pro Previer
    Hey Guys,
    My VIA drivers won't install because it can't find the device. I'm trying the driver from the Biostar Website. I've tried the ones from the via website but those don't work either. I get nice clear audio but i can't configure my drivers so I can get my sub woofers working.
    Links
    Biostar:
    N68S3B :: Motherboard :: BIOSTAR
    VIA:
    http://www.viaarena.com/Driver/v10500d.zip
    http://www.viaarena.com/Driver/v10_1200a.zip
    Check to see if you have installed the chipset driver or if there is an updated chipset driver for your mobo.
    After checking your mobo's page you linked to...seems like that mobo doesn't support windows 8. I only see 2 drivers for windows 8 and those are the LAN/Audio drivers. The drivers that are there don't say what brand/manufacturer they are, very hard to decipher. I'm not a big fan of BioStar anyway.
    Everything else works, and it says the drivers will work on Windows 8.
    Windows 8 Pro Windows 8.1 Preview
    Go here and see if you have an option for surround sound. I do not have that option because I only have two speakers connected:
    Note: click configure to bring up the view on the right:
    Nope, Nothing. I had my sub plugged into the mic jack on my mobo cause vdeck let me use it as an output. If you know of another software that does this PLEASE TELL ME!!!!
Hello, Following the forum guidelines I am posting a compressed file from your SF Diagnostic tool. This was done shortly after a BSOD. Thanks for your support in helping me understand what is the cause of those frequent BSOD. Joce
hello all. I just got my new pc with MS Windows 8. I tried to set up the "People" app and I keep receiving an error which tells me that "Your password has changed. Please enter your password." Howvever there is no place to re-enter my password nor did I change my password. Since I get...
I'll put this edit at the top, so that you won't have to read the rest if you don't want to. I fixed the problem by restoring my system to a restore point created the day I got the computer set up. I'll have to reinstall everything I've put on it in this last week, but that's better than sending...
Hi, On a fresh clean Windows 8 image, my software driver (signed) installs fine and shows up properly in the Device Manager. However once i uninstall it , subsequent reinstalls show up as 'Unknown Device' in the Device Manager. From the device details, I find that it refers to /looks for the...
can't install VIA HIGH DEFINITION(HD) AUDIO DRIVER in Windows 8 Dev. Preview x64.tried 4 to 5 different versions.but none of them would install.i can't get FRONT PANEL HEADPHONE output with default Windows audio.speakers works fine. error : ...
