Sound drivers for Dell Dimension 8400?
    Windows 7 and 8
    I have installed Windows 8 on my older computer, Dell Dimension 8400. Everything worked except my sound drivers. I checked the website and there were 2 available downloads for sound drivers. I downloaded both. One said incorrect hardware, so I assumed that that wasn't right driver. I tried the other, and first it said Wrong OS, so I ran it in recommended compatibility, then it said Incorrect hardware. So both drivers must be incompatible? But when I had windows XP before, it worked perfectly. Not sure why it doesn't now. I also tried using the driver searcher thingy. It was searching for like an hour, and when I tried to stop it, it wouldn't close. I had to force close it, and it found nothing.
    Does anyone know how to resolve this problem? If so, please help me!
    did you insure they said for windows 7, and were for your machine? some machines from dell may have different drivers depending on the configureation of machine even if said machine has multiple OSs that were shipped with it, the hard ware its self may be slightly different example sound blaster hardware (creative) may have shipped with your Dell 8400 with XP but the machine with windows 7 may have been shipped with audio audigy (made up for this example) hardware so the drivers may be different in respects to that, or it could be generic intel driver(s) (i don't think intel makes sound cards but i could be wrong...
    if you know the manufacture of the hardware components (say creative/sound blaster) i would go to the manufactures website and download the proper/appropriate drivers for the hardware on the windows 7 platform...
    Windows 7 and 8
    The drivers were for Windows XP, so I don't know if they are compatible. I'll try going to the websites and manually downloading the drivers.
    Windows 7 x64
    SB Live! series Support Pack 2.0 (04/30/2010) - Creative Labs
    Thats all that you need. It will work for you because I have the same computer running windows 7 for my grand parrents.
    Windows 7 and 8
    wow.. ty ty very much appreciated.
    Windows 7 and 8
    Did not work. I extracted it to my C drive, then ran the installer. I then restarted and nothing happened. Windows still does not recognize an audio device.
    Note: I have 2.5 GBs of ram. The driver said it supports up to 2 GBs...
    The Dell Dimension 8400 has a Creative Sound Blaster Audigy 2 according to cnet reviews.
    Try this driver.
    If it doesn't work try compatibility mode.
    Windows 7 and 8
    Quote Originally Posted by XDleader555 View Post
    Try this driver.
    TY SOO MUCH! This one actually worked!
    win 7 64 pro+win 8 64 , xp 32 pro
    im using an old sound blaster Audigy in win 7 64 and 8 64
    one problem game port ,got drivers from creative,just the drivers no software.
    Quote Originally Posted by Stardust342 View Post
    Windows 7 and 8
    Quote Originally Posted by The4orce View Post
    XDLeader555's link worked for me. You should try it.
Dell Dimension 3100 in Graphic Cards
As my wife's PC was recently attacked by a virus, I decided to upgrade it from the OEM XP to retail Win 8 Pro and then 8.1 Pro. To avoid any risks with viral remnants, I purchased a new 500GB hard drive with the aim of doing a clean install - all essential data being backed up on an external HD....
Dell true to form has made the cmos non-upgradeable for use with WIN8. So, with regrets, I need to know what motherboard, cpu and sound cards, memory, etc, I will need in order to upgrade this elephant. :dinesh: Then of course, I need to know if my graphics card, NVIDIA GeForce 6200, power...
Hi guys I own a XPS L702X laptop purchased in 2011. Laptop has driver support from Dell for Win 7 and Win 8. But windows 8 drivers aren't working with windows 8.1 and i don't think Dell is in the mood to provide drivers for a laptop which is already 2+ years old. So i had to collect drivers by...
My computer was beeping on start up and would start beeping randomly while the computer was on. Sometimes it would beep non-stop and I would have to disable the internal speaker. I updated the bios and that fixed the problem, but my webcam driver and internal mic driver isn't working anymore. I've...
i dont know that i am posting at right place or not. i have very little knowledge in software installing ...now i want to upgrade my windows 7 with windows 8 but i have dell laptop with old drivers of windows 7. so i am confusing that will that same driver work again or i need to have diffrernt...
:cry: i have windows 7 now and want to upgrade windows 8 but i am scaring about the problem that may occur after installation so i have some questions please help,,,,seven forum was so active and responding but eight seem quite slow....\ 1. what driver is pre exist in windows 8 2. should i...
