wlm sound ..
    wlm sound ..
    wlm 2012 not playing my notify sound that is present & checked in the sounds menu of control panel..
    Hello delicate,
    Double check in your "Sound" settings to make sure that you have both the Desktop Mail Notification and New Mail Notification events checked and a .wav file assigned to them.
    Next, while in WLM, click on File -> Options -> Mail, and check to make sure that you have Play sound when new messages arrive checked like below.
    Hope this helps.
    This is confusing lol
    but I checked desktop too & it now works, thanks.
    You're welcome. Yep, they both need to be checked.
wlm sound ..
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
