Sound not working!
  1. #11
    Driver Fusion, at least what I have, does not include RealTek Sound, just RealTek Network.
  2. #12
    The back one works! thank god, ill just buy a cheap speaker today, ill open her up later and see if when i was dusting it out that i didient loosen the audio wire or if unplugging and plugging it back up will work, i thought those connectors on the back were for wires that hook up to the tv..
  3. #13
    from one Jack to another. Glad you got it partially sorted out. Try the cable reseat, first.
  4. #14
    nvm, it was working in the green one but left speaker only, and now its not working at all :/
    i dont know whats going on with my pc...
  5. #15
    Make sure the headphone plug is fully inserted if its only partially inserted you will only get one channel.
  6. #16
    nope, but what i did notice (ifi it helps) that the blue plug doesnt work then i plugged it into the pink plug nothing, but when i returned to plug it in into the green then there was no more sound, what im considering is a bluetooth speaker, now that i know the sound is working maybe bluetooth will get me my sound unitll i figure this mess out. i aslo opened it up and all i could really do was un plug the leads that connected to the front panel with the audio. im guessing that this is a hardware failure...
  7. #17
    The Blue is "Line In", not an output so it wouldn't work. Same way with the Pink one, that is for the Microphone.
    Bluetooth has its own problems. A USB may work, but until you get the sound chip working in the PC neither Bluetooth or USB may not work.
    Try a different headset, if you have one, even one of the small ear bud type, just to see.
    If you go to the Sound panel/Playback section, click on the Speaker icon to highlight it and then click on Configure and you can test the sound there with your headset. "Stereo" (or something similar is what should be selected for the speaker type).
    The only other thing is, since you cleaned it out, you could have inadvertently zapped something on the motherboard. I would still call Dell support if its still in warranty. Let them figure it out instead of beating your head against it trying to figure out what is wrong.
  8. #18
    Well could i try uninstalling then reinstalling the audio jack rear/ front drivers? as a last hope thing? before i have to take it into an pc repair shop (not best buy, geek squad is a terrible service, also expensive)
  9. #19
    You can try uninstalling the RealTek in the Device Manager. When Windows starts it will detect and reinstall the sound. Give it a try. In the Device Manager, RIGHT click on the entry for the RealTek and then LEFT click "uninstall" DO NOT check the box to also uninstall the drivers. Restart the PC.
  10. #20
    there is no realtek driver or thing here, hmm could that be the problem?
Sound not working!
Hello everyone! I'm having a big trouble with my windows 8. Yesterday I was watching a clip on YT and suddenly the sound stopped. I tried to restart the computer. I didn't work. The sound on YT is on full voulume as well as on my computer. Then I went to sound configurations. I clikc 'configure my...
Windows mail on windows 8.1 will not play notifications, I setup a custom wav sound and set up notifications in windows mail and it still doesn't notify me.
Sound Card not working in Sound & Audio
Sound is not working in Sound & Audio
I installed windows 8 on my PC 3 days back. The problem i am facing is that it's sound is not working. I heard we don not need to install additional software to make sound working. But this is not working in my case. Please help me resolve this issue. Thanks in Advance Reyna S Content...
Sound not working in Sound & Audio
Sometimes I am watching a movie on my PC and all of a sudden the sound goes away on everything and I have to restart to get it working again. Anyway to fix that so it won't happen anymore?
Sound not working! in Sound & Audio
Recently my computers sound has all of a sudden stop, this forced to go back to my usless piece of junk toshiba sattelite, when i click the volume button i can see the green bar go up and down when a video is playing showeing that the sound works but when i plug in heaphones nothing, and its a...
After installing Windows 8 Pro X64 was prompted to download cmedia sound driver to get m onboard sound chip to work.:( Downloaded the 64bt version, went to install and got message saying it wouldn't work with my system :shock:
