High pitch hissing sound?
    A month or two ago I purchased a desktop computer, dell vostro 200. intel dual core 2.8 with a PNY GTX260 graphics card. I haven't plugged in the earphones at all until now and I noticed this hissing sound. Its pretty loud, I'm not sure why but whenever I move the mouse a tad, there's another sound that joins in. What could it be? I turn the volume to 0 and I still hear the hissing sound.
    Maryland USA
    sounds like a loss of shielding or ground
    Try another set of headphones
    Your headphone jack may be damaged.
    If hiss continues, then disable your microphone
    right click the speaker icon, choose recording devices, disable the microphone
    The headphone jack has to be damaged, I used the one on the back and its working perfectly. Thanks
    Maryland USA
    could just be dirty, try plugging and unplugging the cable several times and see if it clears up.
    if holding the cable to the sides while its plugged in eliminates the hiss then its pretty sure that its broken.
    Dell had a problem a couple of years ago with routing of the front panel headphone/mic jack, in an XPS model, that caused noise. Rerouting the cable, in this case away from the hard drive, fixed the problem. Check the routing of the cable in your Vostro and see if that will make any difference.
    Was this a new Vostro? The Vostro line was recently discontinued.
Hello everybody. Before I start I just wanted to say , sorry for the bad english . So , I have read allot of forums lately , and I found out that windows 8 and windows 8.1 weakness is its latency. For me this proplem accoured like 2 months ago (before it didn't happend) , and yes I have messed...
High RAM Usage (Spotify high) in Performance & Maintenance
First off I have 8GB of RAM, and I get notifications all the time that my RAM is high, and it wants to close programs. The main program that worries me the most is Spotify is using 900MB of RAM when playing and 500MB when not playing. Why is this so high? The games I play are not even that high....
Hello, I tried so many things, running out of idea. Hope someone can assist. Updated all drivers, realtek, nvidia, amd chipset and bios. Remove everything from USB post and booted without services, disabled network drivers. When I uninstall the nvidia drivers I dont get that much latency, I...
IDT High def, low sound in Sound & Audio
Hi ! I got some problemt with the sound on my laptop after installing Windows 8. The sound is very low when i turn it on loud, i dont do anything in the properties to the sound card. It was perfect on windows 7 and on win 8 it is low. Any help ?
I have recently been experiencing an issue where the speakers are making a very annoying high pitched noise that sounds like a dog whistle or something. The interesting thing is that the pitch of the noise changes in steps when I adjust the volume. Also, it only makes this noise when no other sound...
I have set the volume mixer to low volume for "System Sounds." However the UAC alert sound seems always to be at maximum volume, which is not tolerable. My only solution so far has been to mute System Sounds completely in the volume mixer. At least that shuts that loud UAC sound off. Is this...
Framing Windows 8 with the Flexible Workstyle Pitch Training for Microsoft Partners - Softpedia
