HDMI Sound output issues
    Hi there,
    new to this forum but i've been searching around today trying to find an answer to this problem i'm having.
    I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both allowed and still i dont seem to get an option for HDMI for audio. The picture has come through fine, but nothing I do with the audio seems to work.
    Any suggestions please?
    Windows 8 Pro Windows 8.1 Preview
    There might be an option in your BIOS for HDMI audio output. I have these options: Auto, Enable, Disable.
    Where can this be found? I've had a look in most places i can think of.
    You have to access your BIOS during boot. Directions should be in the user's guide for your laptop or PC (model not provided).
    Sloe Deth, Californicatia
    What kind of Laptop and does is use any kind of Intel chipset for Video? I had a Gateway that had the same problem, I had to download a Vista driver for it and force it in manually.
    So, did you fix it?
    Hey its an Acer laptop E1-571.
    No, the problem still seems to be the same. There is no driver for it and I can't seem to find one.
    Any help would be great.
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
HI, I'm new here. I run the sfc /scannow like 5 times because when I did it, it broke or damage my HDMI output. The only problem my sfcdetails.txt file shows is that it cannot repair Amd64\CNBJ2530.DPB of the prncacla.inf file due to a hash mismatch. But you already wrote that it doesn't had to...
HDMI output not working in Graphic Cards
Hey guys, I have an ASUS s550C running windows 8 and my HDMI to my 32" RCA flatscreen doesn't work anymore. The cable works fine with the xbox, correct tv modes, but now as soon as I plug in the HDMI to the Ultrabook the Ultrabooks screen goes black and the tv screen says unsupported. What gives?...
Okay so, my computer recently crashed and had to reformat it.. lost everything :( Everything was working just fine, until I had to reformat. Now, I have no sound at all coming from my headphones and it says that the AMD HDMI Output is not plugged in. I don't really know how to fix this.. ...
Hi, Issue: Since upgrading my Windows 7 laptop to Windows 8 (64bit) it has lost functionality for both gaming and HDMI output. My Setup: HP Pavilion Dv6 - 3050sa BIOS: Default System BIOS Processor: AMD Phenom(tm) II N620 Dual-Core Processor (2 CPUs), ~2.8GHz Card name: ATI Mobility...
