Random Volume Fluctuations
    Windows 8 Pro
    So I've been having random volume fluctuations with things like youtube and iheart radio, as well as the occasional games. I've been searching the forums for a solution but the closest i can find is on the W7 forums, (Volume level continuously changes - Windows 7 Help Forums), which is the same problem I'm having with windows 8 pro. The last post on that thread is from September of 2012, so really I'm just curious if any new info or solutions have been made available. Like the op in that thread I as well disabled my communications and turned of the enhancements. I also uninstalled my audio drivers, restarted, and when it rebuilt the drivers they were newer than the ones i had. (Realtek 6.2.9200.16497, current driver) Yet still the problem persists. Team Speak 3 is the only web voice chat service i use, but that's only on when running a game. Any help is much appreciated.
    Does this happen on both the Laptops internal speakers and headset? Or just one of the devices?
    Also on ANY audio or just specific items?
    The other user noted the problem was being caused by teamspeak.
    Windows 8 Pro
    So far i seem to only notice it when i hook it up to my flat screen with the hdmi. Ive disabled the mics in both TS and in the sound conrols, and while it seems to make the fluctuation less extreme its still noticeable. It happens most with anything that i watch online, fallout 3 and minecraft. after that watching a dvd seems to have no effect and plays audio as it should.
    Windows 8 Pro
    Go figure..... it was the true volume setting in the flat screen itself. So thanks for replying fireberd and i guess -1 internet for me.
    Interesting. At least its fixed, or you know what causes it.
    Windows 8 Pro
    yah... im not an expert by any means but im at least more savvy than the average user. i just recently bought this laptop and switched the flat screen from W7 tower straight over and had no issues with it prior to this laptop. random guess is W8 integrates sound better with the FS better than W7 did, but again random guess....
    side note: your avatar seems strangely appropriate for this post
Mic volume too low in Sound & Audio
Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
BSOD at Random Times for Random Reasons in BSOD Crashes and Debugging
DCP Watchdog, Memory Management, Kernel Security Failure and several others at random times - especially during large file transfers between drives. I did a memory test and it stated there was an issue but I removed the culprit and the random BSOD continues. Thanks for your help
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Hey guys, so I am in a bit of a pickle. I have an HP m6-k015dx laptop and it is giving me hell. I will get random BSOD's, usually at or a short while after login. They usually happen consecutively and then stop. I was able to enable driver verifier in order to see what was wrong. After it was...
Solved Volume OSD in Sound & Audio
Solved it on my own! I just ended the Task Manager task, everything seems fine, nothing has died yet :sarc:. So I've been running Windows 8 for a while now, upgraded from Windows 7. Now that Microsoft has implemented a pretty good looking volume OSD I would like to disable the default one....
Solved Win 8 on volume 2,4? in Installation & Setup
Yep guys I've installed win8 on my HDD, after that everytime I boot to win I got this screen: 11368 After 5sec it will be boot to win 8 on volume 2. I have no idea why I have too much win 8 on diffrent volume. Can someone help me fix it?
