New/Old Surround Sound system
    Sloe Deth, Californicatia
    I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price.
    So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable - Which sends the PCM Output into the receiver, ok, got that done.
    But one of my computers connects via the stereo audio Line Cable from the back of the PC, and that system uses the RGB Video for the HD Video. So I am not expecting any Surround Sound from that (this) system.
    But my Media system, uses a GEForce 210 which has the Digital Output on the HDMI cable. When I set it up in Media Center, it sends the 5.1 to my TV, but from the main Audio Output, there is no Surround Sound available. There is also a Falcon Tuner Card in there, but I never use it because I can't use it- I'm missing the Remote so it can't be set up. I was using it to Capture my TV from my Cable Box, but it's not so good.
    It used to be when I set up the Audio Output for the HDMI in Windows 7, I had the choice of setting up 5.1 - But in Windows 8, it's gone, I can only choose Stereo.
    Any ideas where my 5.1 output went to? When I use the forced/fake Surround Headset mode in VLC, it sends to all speakers, but it's not real 5.1. Is there some setting somewhere I'm forgetting to check?
    install latest audio drivers supporting your woofers.
    now goto run command
    type compmgmt.msc
    goto device manager and right click sound,audio manager
    click on scan for hardware changes
    and reboot.
    Your device would be setup and will show your audio options
    Ok, but I thought I had the latest Driver for my nVidia card - Is the 3.20 driver out of Beta?
    Ok, Updated but still no Surround Sound available on the Hardware Configuration. I don't understand, as it works well from within Media Centre.
    You think the Falcon card may be interfering?
    I found a way around this - My system IS sending out Surround signals, but only when VLC Media Player is playing 5.1 content. I told it to use S/PDIF automatically when detected and I changed the 5.1 setting to "ON" instead of "Automatic"- BOOM there's my surround signal. I was surprised what content had it and what did not. So my system defaults to stereo when it is not present, this saves me from having to switch the sound on the power amp.
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Previous versions of windows used to allow you to customize system sounds for mouse clicks. In Windows 8 system sounds, there doesn't even appear to be an entry for the mouse click events. Am I missing something? How could I add back sounds for mouse clicks?
Solved Missing sound system in Sound & Audio
I used to have a sound system that ran from my sound card but it doesn't seem to be anywhere, here is what I have under "sound" in Device Manager My system Windows 8 IE10 31268 I do have sound but its always playing up. Regards, iknownuffin70 Why ever did I purchase a computer.???
Streaming to surround sound in Sound & Audio
Hi guys, I want to stream my music and videos from my laptop to my smart tv via Wi-Fi so I can listen through my surround sound system. I cannot seem to do it through the music and video apps in win 8.1 Anyone know how to set the apps to stream to DLNA devices? Thanks
I have tried for some time now to get my surround sound to work on my Packard Bell Ixtreme X8540 since upgrading to Windows 8 via Microsoft's upgrade tool. When I had Vista installed, there was an icon on the bottom task bar which would take me to a control centre for the audio which gave the...
Since upgrading my HTPC to Win 8 Pro 64 bit I cannot hear my surround speakers anymore. When I do the speaker config, the sound that is supposed to come from my surrounds is instead coming from my front right and front left speakers. I am using a GTX 460 GPU as my sound card. I have the latest...
