Microphone volume very low
    Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix.
    I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work.
    I've read that you have to go to the microphone, double click on it, go to the levels tab, and move the lever all the way up, as long as the boost lever. I don't have the boost. Only the microphone is present as you can see in the screenshot. That doesn't work.
    I just downloaded Windows 8 last Thursday so all of my updates are installed. I updated to the latest drivers for my sound card thing, which I guess is intergrated. Now, before you tell me it's my mic, before Windows 8 I was using xubuntu until I could afford Windows 8. My microphone was fine. It picked up great. I could hide it behind my monitor (which is atleast 3 or 4 feet away) and it would still pick up fine. Now in order for it to pickup my voice like it did behind the monitor I have to have it literally 1 cm away. I honestly don't know what to do anymore.
    If you'd like to hear some example of how it works now, please feel free to listen to the links below. I'll show what they sound like next to my face and then what it sounds like where I use to have my mic. Please note that the voice isn't really my real one, just a mock-up one.
    Next to my Face: https://soundcloud.com/uehm1/next-to-my-face
    Where my microphone usually is: https://soundcloud.com/uehm1/regular-distance-away
    Thanks for any help.
    Please fill in the "My System Specs". It helps us to try and help you.
    The first question, do you have the proper sound driver installed? The PC Vendor (or motherboard in a custom system) sound driver is the preferred. If you have "High Definition Audio" installed that normally says it is only the basic function generic Windows installed sound driver and not the correct driver.
    Hi,
    I've filled in my system specs. I went to the gigabyte website and installed the drivers and still no progress.
    Since you have a HDMI TV, that says HDMI is being set as default audio playback device (unless you manually change ever time you reboot the PC). This may be what is affecting the mic.
    Try working only with the PC's sound card (set Speakers as default audio playback device) and see if you still have the problem.
    My headphones are currently the default playback device. It automatically boots into this mode and I've only had to change this the first day I had Windows 8. I'm still having this problem and have tried setting both the TV and the headphones as the default device.
    Is it actually recording low or just that its low in the speakers as you use the mic? Or, is it low in some program such as Skype?
    Yeah, it's low in programs like Teamspeak and Skype. I've tried to manually set the microphone volume in each program but it's still low.
    I don't have or use either program so I can't help you with those.
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
Hello! I have a Blue Snowball microphone which is a great mic, but and as you might know, it sounds like a vulcano errupting next to an exploding nuclear power plant if you have it set to 100% volume. That's why I have it at 60% and later boost the recordings in editing programs. The thing is that...
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Solved Microphone in Sound & Audio
So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP :( 26062 26063 26064 26065
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
8 microphone in Sound & Audio
microphone not working
