How to use the StereoMix and Headphones mic at the same ?
    Windows 8 64 bit
    I need to use StereoMix and my headphones built in mic at the same time. The problem is IF StereoMix is enabled, only the PC's internal Mic is activated. I cannot activate my headphones mic unless i disable the StereoMix device first.
    Normally, that is not the case. If you have Stereo Mix set as the default recording device (not just "enabled") then any input, e.g. internal or external mic is also activated (heard).
    Are you using the HP supplied audio driver?
    Windows 8 64 bit
    Yeah I'm pretty sure I'm using the driver that came with the laptop. I set StereoMix to Default Device and suddenly the headphone Mic becomes " Unavailable". I MUST make this work even if I have to jump through a lot of hoops or install a copy of Windows 7.
    Do you have anymore thoughts on the matter?
    Go to the Device Manager and see what you have listed for Sound, Video and Game Controllers, You should only have the IDT audio and possibly AMD (HDMI) audio, if you have HDMI capability. If you have anything else, that may be conflicting and causing the problems. If there is anything other than the two entries, RIGHT click to highlight the device and the LEFT click Uninstall. Restart the PC and see if this fixes it.
    If there are no entries other than the iDT and AMD, the problem MAY be a corruption in Windows for the sound. Uninstalling the audio device and then a reinstall will correct any corruptions. Uninstall the IDT audio, in the device manager (same procedure as listed for an extra item) then restart the PC and when Windows starts it will detect and reinstall the sound. See if this fixes it.
    If still bad, reinstall the HP provided sound driver and give that a try.
    Windows 8 64 bit
    Under Device manager there are only the AMD High definition audio and the IDT High definition audio listed. I have tried all your suggestions above even uninstalling the IDT driver and it's software and reinstalling them. I still get the same results with no change no matter what step i took.
    Thanks for trying. If you have any more thoughts I'll try em.
Headphones not recognized in Sound & Audio
Hi, my computer doesn't recognize my headphones. The speakers work fine, the headphones work on other devices. They used to work on this pc too, but a few hours ago my friends and I were trying to record something with a mixing table and they had to change a few things for it to work. I have no...
Hi I have a Logitech 540 and another Logitech 3XX USB headphone & mic and I'm wondering can I easily configure them to both work simultaneously? The application is for a Google Voice call. So two people can conference call another person from one computer.
Headphones problem in Drivers & Hardware
I have a problem with my peadphones .I plugged in the headphones and my windows it's tell me the are not plugged in. I instal an audio driver and they work but I reinstal the windows and I not whant to instal an audio driver.It's any way to have the headphones to work without an audio driver?
Headphones Problem :/ in General Support
Well my speakers do produce sound , but my headphones do not produce even the smallest amount , NOTHING. In windows 8 professional they don't work , but in windows 7 ultimate they do work...Anything like a help ? Maybe the headphones driver? I've got TURBO-X headphones , they have got 2 jacks or...
Headphones Not Working... in Sound & Audio
First of all my speakers DO PRODUCE sound but when I plug - in the headphones , they do not produce sound at all...Before some1 says go to r1ght click on the audio thing and properties from there to Enable it , I'll have to tell you Headphones aren't even existing there... I don't know what to do...
No sound with headphones? in Sound & Audio
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
