I need to use StereoMix and my headphones built in mic at the same time. The problem is IF StereoMix is enabled, only the PC's internal Mic is activated. I cannot activate my headphones mic unless i disable the StereoMix device first.
- Windows 8 64 bit
- System Manufacturer/Model
- HP Pavillion G7-2251dx
- CPU
- AMD A-8 4500M
- Memory
- 8 Gigabytes DDR3 sdram
- Graphics Card(s)
- Discrete ATI Radeon HD 7640G with 2 Gigs
- Sound Card
- IDT Audio
- Monitor(s) Displays
- 17.3
- Screen Resolution
- 1600x900
- Hard Drives
- 500 gig
- Internet Speed
- 3.5 mb/sec
