Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
    New York
    Windows 8 Pro 64-bit
    Basic Specs
    Brand New Toshiba Satellite C855
    Win 8 64-bit
    6 GB RAM
    Display Adapter: Intel(R) HD Graphics (2000)
    Driver: Intel 9.17.10.3040
    Playback Devices
    Show Disabled Devices - checked
    Show Disconnected Devices - checked
    High Def Audio Device displays as not plugged in
    1. Cable is plugged in
    2. Cable has been tested on backup laptop
    3. Cable connected to HDTV
    4. Video is fine
    5. No Audio
    I have spent hours installing and uninstalling drivers from the Toshiba and Intel sites. Tech support said to return it but I have just spent 2 days installing software. I never took a break to watch Netflix. Any suggestions will be greatly appreciated!
    The video is apparently not detecting the HDMI cable. Assuming you have a good HDMI cable it suggests a hardware problem in the new PC.
    New York
    Thanks for your response. I would agree where the problem not widespread. I find it hard to believe that there are so many malfunctioning pc's. I'm going to give it a few more days and then return it.
    Is there a good way to save all of the work I've done?
    As fast as PC's are produced, anymore, I'm surprised there isn't more "bad" ones. They don't do the "burn in" like they used to do and that results in less quality control.
    Reinstalling the Video drivers, from the PC vendor, is about the only other thing you can try.
    Reinstalling the Video drivers, from the PC vendor, is about the only other thing you can try. The "High Definition Audio Device" for the HDMI suggests the proper driver is not installed and only the generic Windows installed (basic function) driver has been installed.
    New York
    I've gone to the Toshiba site and downloaded numerous drivers and when I get to the install point they all say that my computer does not meet minimum requirements - see the attached screen shots.
    Click image for larger versionClick image for larger version
    I find this pretty amazing as the process begins with my entering my pc's serial # - you would expect the correct drivers to be listed. Really bad website design, really bad support. The phone support is non-existent - they want to charge me!
    I had a Toshiba 10 years ago that was a dream - then a nightmare Dell - now I have a problematic Toshiba.
    I will keep trying earlier drivers. I've already tried the ones from the Intel site - they either don't fix the problem or don't install.
    Any further thoughts? Please! Thanks again for your help.
    Chicago USA
    Windows 7 Pro and Windows 8.1 Pro 32 bit and 64 bit
    Quote Originally Posted by penTechCoach View Post
    Basic Specs
    Win 8 64-bit
    6 GB RAM
    Playback Devices
    4. Video is fine
    5. No Audio
    All HDMI cables are not created equal. I bought a cheapie trying to save a few bucks and I had sound and resolution problems. I kept getting "unknown timing" errors until I bought a good quality cable. The cable I had was fine on my full sized laptop but gave me problems with a netbook. A new cable solved the problem.
    New York
    Thanks so much - I'll try a friend's cable before I buy a new one. Actually - I'll also try another TV while I'm at it! Thank you again!
    Since this apparently has Intel video, you can go to the Intel site, let it scan the PC hardware (it will install a temporary program for scanning the PC) and then install the driver direct from Intel.
    Ultrabook, SmartPhone, Laptop, Desktop, Server, & Embedded? Intel
    Chicago USA
    You said you had video but no sound. When you look at your sound playback do you have the device listed there? My TV shows up as TOSHIBA-TV. I had to set the device as the default sound to get it to work. (See Sound picture)
    Also you can try changing your screen resolution to see if you get sound using a different screen resolution. I don't know why it would have any effect on the sound but based on my troubleshooting I was able to get sound at some lower resolution with my netbook that was having the problems. (See resolution Picture)
    These screenshots are from my Win7 desktop. The Netbook I was having problems is Win8 Pro.
Page 1 of 3 123 LastLast
HDMI cable buying guide in Chillout Room
Read more at source: HDMI cable buying guide | TV and Home Theater - CNET Reviews
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI....
Title pretty much sums it up, I have a AMD 5650 that shows a black bar that is 1 inch on the left and right and about .5 inches on the bottom on HDMI ive used the drivers that Microsoft provided and also beta drivers from AMD from Febuary 2014, nothing seems to work. Ive taken a picture sorry if...
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
Hi, I recently connected a different monitor to my pc but it only works with VGA, When I connect HDMI cable it acts like there is no cable connected. I got hdmi to work abit but I have to use very low resolution. What could be the cause of this? Monitor is Polaroid TLU-01911C Thanks
