Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
  1. #21
    New York
    Windows 8 Pro 64-bit
    Thanks so much for helping me. I see exactly what you've done but I can't locate the DisplayAudio folder on my system. Where exactly is it on yours? Thanks again.
  2. #22
    Win 8.1
    Quote Originally Posted by penTechCoach View Post
    In my case, I downloaded the latest driver for my display adapter (Intel Iris 5100) as a ZIP file. After unpacking the ZIP, there was a folder called DisplayAudio that contained the HD audio driver. As I mentioned, the main Display driver was installed by a Setup.exe, but the HD Audio driver had to be installed separately (manually) from the DisplayAudio folder.
  3. #23
    New York
    Thanks for your help - I'm having problems doing the same at the Intel site. There's a Java problem but I have it installed. I'm getting a new flatscreen in a few days - I connect my laptop to an ancient Samsung syncmaster that refuses to die and a crap flatscreen (Coby) in order to stream. I'll replace the Coby and perhaps the problem will be solved. I also have an external speaker. Thanks so much for all your help. I'm going to mark this solved as I think you have provided the correct answer and the problem lies in my flawed implementation - lol!
  4. #24
    Windows 7 Home Premium 64
    Thanks to BoulderJ
    Thank you BoulderJ! I just completed my HTPC build and was getting no audio over HDMI. Spent days looking for the problem. Your clear description of the problem and solution were exactly what I needed.
    There are similar threads on the Intel Community forums, in particular for HD Graphics 4400 and 4600, where many others are baffled by this issue. I took the liberty of referring them to your post.
  5. #25
    Have got to say thank you for posting was having issues with my Zbox with a Intel HD 3000 graphics behaving really strange. My Zotac Zbox ID82U was running Intel HD 3000 then through a VSX-1023 to a LG 60PB5600 and had video but no audio. Followed your directions and saved me endless time/effort. Was just about to package the LG up and send it back but this saved me having to do that. Thank you Thank You.
    Hope this helps many other people with the same issue.
  6. #26
    Quote Originally Posted by BoulderJ View Post
    I've seen several of these posts about HDMI audio not passing to an external monitor (e.g. TV). I had this problem and found the solution, so I thought I'd pass it on. My PC is an Asus notebook running Win 8.1 with an Intel Iris 5100 Graphics adapter and Realtek HD Audio. While what I found may not apply to your system, I'm guessing it does to many.
    The problem was recognizing that for HDMI output with audio, there are three (3) drivers involved:
    1. The Display driver (e.g. Intel Iris Graphics 5100)
    2. The Audio driver (e.g. Realtek HD Audio)
    3. The Display Audio driver ("Display Audio" part of the Display driver)
    After installing the latest drivers for 1 & 2, I then:
    - Rebooted the PC
    - Plugged in the HDMI cable to my TV
    - Switched the PC display to Duplicate on the external monitor (TV)
    At that point my Device Manager looked like this:
    Attachment 35250
    and my "Playback devices" in Sound looked like this:
    Attachment 35251
    I then installed a new driver for the "Display Audio" device. The new driver was part of my (Intel Iris 5100) Display driver files and located in a folder called "DisplayAudio". There was no Setup.exe for this driver, so it had to be installed manually - in other words, right-clicking on the Display Audio device in Device Manager and selecting "Update Driver software" then "Browse my computer for driver software".
    After installing this driver, I did the reboot, plug-in in HDMI cable and set Duplicate display again (you have to do all three steps after each new driver install).
    Attachment 35253
    Attachment 35254
    HDMI with audio is now working properly for me.
    If you find a similar situation on your system, this should work. Good luck.
    This worked for both of my Asus laptops. I actually had to download the Windows 8.1 version of the Intel Driver for both Windows 7 and 8.1. I googled "Intel Display Audio" and it takes you to "Other downloads for Intel HD Graphics". Then just as BoulderJ says, you update your High Definition Audio Driver and select the zip folder you just extracted (DisplayAudio).
    Thanks BoulderJ!
Page 3 of 3 FirstFirst 123
HDMI cable buying guide in Chillout Room
Read more at source: HDMI cable buying guide | TV and Home Theater - CNET Reviews
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI....
Title pretty much sums it up, I have a AMD 5650 that shows a black bar that is 1 inch on the left and right and about .5 inches on the bottom on HDMI ive used the drivers that Microsoft provided and also beta drivers from AMD from Febuary 2014, nothing seems to work. Ive taken a picture sorry if...
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
Hi, I recently connected a different monitor to my pc but it only works with VGA, When I connect HDMI cable it acts like there is no cable connected. I got hdmi to work abit but I have to use very low resolution. What could be the cause of this? Monitor is Polaroid TLU-01911C Thanks
