Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
  1. #11
    New York
    Windows 8 Pro 64-bit
    Sorry I did not see the last two replies until just now.
    fireberd -I did go to Intel and load the most recent driver - I believe it ended in 3097. When I did that my system did not even display Digital Audio - just the Realtek speakers. So I began installing earlier versions - 3040, 2843, 2828 until I got it back. Some where on the Intel site it is recommended that the brand-specific drivers be used as they might be tweaked by the manufacturer. So now I have version 2828 from the Toshiba site installed.
    Thanks again for you help.
  2. #12
    New York
    Hi mick823 - sorry I did not see this earlier but I had to get a new phone and then spend hours adding software to that.
    Just now I tried lowering the resolution on my connected TV but it did not work. I don't see my TV listed under playback devices - just the laptop's internal speakers and Digital Audio (HDMI). Did you get that driver from the Toshiba site? I just want the laptop to output sound to any HDTV - not just mine.
    Thanks for your help.
  3. #13
    New York
    Problem Resolved With Workaround
    Okay -
    I bought a 1/8" 3.5mm to rca cable - did not work. And yes - there is sound using headphones. Last try - a simple 3.5mm connected to TV using PC AUDIO IN socket and it worked.
    I still think this is driver problem as I was able to get by with just the HDMI cable on my crap Dell that now gets so hot it shuts down in 10 minutes - but that's tomorrow's dilemma.
    Now I can watch True Blood on HBO GO.
    Thank you all - this is a great forum - so many helpful people.
  4. #14
    Chicago USA
    Windows 7 Pro and Windows 8.1 Pro 32 bit and 64 bit
    Quote Originally Posted by penTechCoach View Post
    My WIN8 netbook is a Gateway and the WIN7 desktop is a Dell. As soon as I plug the HDMI cable from the TV into either of them my computer screen turns black for just an instant as it recognizes the hookup. At that point I have dual screen set-up and the HDMI sound is recognized as TOSHIBA-TV. It still won't output sound to the TV unless I set it as the default sound. Not really a problem because as soon as I disconnect the HDMI cable it reverts back to the computer speakers. If you are still not seeing the TV on the sound devices my gut feeling is that it is a cable issue and not your driver at all.
  5. #15
    New York
    Hi again -
    I don't have that option - I just see Digital Audio unplugged (HDMI). This option is disabled - I can not set it to be my default. This option is there regardless of whether I'm connected to the TV via HDMI. Nothing changes when I plug the TV in other than both screens going black and my external monitor being extended onto the HDTV.
    It all worked just fine with my crappy Dell but very differently. On the Dell I only see speakers until I plug the HDMI cable in - then two identical entries for AMD HDMI Output show up and one is set as the default.
    The Dell has Win 8 Pro on it. I'm going to update the Toshiba to pro - perhaps that will help. I can live with the two cables. I'm going to pick up a better hdmi cable as well.
    Thanks again for your help.
  6. #16
    Chicago USA
    There are cheapo cables and then there are HDMI certified cables. I think I ended up buying a Monster or Belkin Cable. About $20 for a 6 footer. Post back your findings if you get it resolved. Good Luck!
  7. #17
    New York
    Will do! Thanks!
  8. #18
    New York
    I did get a more expensive HDMI cable - still no luck. I'm going to upgrade to Win 8 Pro - perhaps that will solve the problem. I'll post an update. Thanks again.
  9. #19
    Sloe Deth, Californicatia
    Those Intel cards with HDMI output are tricky - I was running Windows 7 on a gateway, it has the Intel HDMI. No SOund from HDMI, until I downloaded the Windows Vista driver for the HDMI, I forced it in and it worked. You can't install from the package, because it says not the right OS. you have to extract the package CAB file and install them manually. When I did that, Boom, HDMI sound. There were no 7 drivers for that laptop, it was an old 17" Original Core Duo laptop.
  10. #20
    Win 8.1
    HDMI Audio Problem Resolved
    I've seen several of these posts about HDMI audio not passing to an external monitor (e.g. TV). I had this problem and found the solution, so I thought I'd pass it on. My PC is an Asus notebook running Win 8.1 with an Intel Iris 5100 Graphics adapter and Realtek HD Audio. While what I found may not apply to your system, I'm guessing it does to many.
    The problem was recognizing that for HDMI output with audio, there are three (3) drivers involved:
    1. The Display driver (e.g. Intel Iris Graphics 5100)
    2. The Audio driver (e.g. Realtek HD Audio)
    3. The Display Audio driver ("Display Audio" part of the Display driver)
    After installing the latest drivers for 1 & 2, I then:
    - Rebooted the PC
    - Plugged in the HDMI cable to my TV
    - Switched the PC display to Duplicate on the external monitor (TV)
    At that point my Device Manager looked like this:
    and my "Playback devices" in Sound looked like this:
    I then installed a new driver for the "Display Audio" device. The new driver was part of my (Intel Iris 5100) Display driver files and located in a folder called "DisplayAudio". There was no Setup.exe for this driver, so it had to be installed manually - in other words, right-clicking on the Display Audio device in Device Manager and selecting "Update Driver software" then "Browse my computer for driver software".
    After installing this driver, I did the reboot, plug-in in HDMI cable and set Duplicate display again (you have to do all three steps after each new driver install).
    HDMI with audio is now working properly for me.
    If you find a similar situation on your system, this should work. Good luck.
HDMI cable buying guide in Chillout Room
Read more at source: HDMI cable buying guide | TV and Home Theater - CNET Reviews
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI....
Title pretty much sums it up, I have a AMD 5650 that shows a black bar that is 1 inch on the left and right and about .5 inches on the bottom on HDMI ive used the drivers that Microsoft provided and also beta drivers from AMD from Febuary 2014, nothing seems to work. Ive taken a picture sorry if...
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
Hi, I recently connected a different monitor to my pc but it only works with VGA, When I connect HDMI cable it acts like there is no cable connected. I got hdmi to work abit but I have to use very low resolution. What could be the cause of this? Monitor is Polaroid TLU-01911C Thanks
