Realtek HD audio not showing up in device manager
    I'm using a windows 8 pavilion g7 laptop. Long story short, I wanted to have realtek HD audio on my computer mainly for the cool audio effects that come with it because the audio drivers that came with my computer don't have those effects. Nonetheless, I installed realtek HD audio hoping it would install and i could simply change the audio settings to use realtek instead of the ones on my computer. once the installation was complete and after i rebooted and everything, I couldn't find the driver for realtek. So i went into sound, video, and game controllers under device manager and didn't find the realtek driver listed. only the two audio drivers that came with my computer. The two audio drivers that came with my computer are as follows: AMD high definition audio device and IDT high definition audio device CODEC. I tried to uninstall them and just reboot but my computer ended up automatically reinstalling those devices anyway. I don't get it. It's like my computer can't recognize the realtek driver or something. At this point I'm not even sure if my computer will allow that kind of audio device. PLEASE HELP!
    You list IDT High Definition Audio. This is your PC's sound "card". You can't install RealTek as there is no RealTek audio chip. You can ONLY use IDT drivers, and the Vendor (HP) supplied drivers are the preferred.
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
I have Z87 G43 Gaming Motherboard, it is strange that the Realtek Audio manager no longer starts automatically on startup. I see there is no startup icon in that folder. I uninstalled and reinstalled the Realtek software, but still it does not start automatically. Not sure what could be the issue....
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
Hey guys, My audio disappeared and stopped working. my audio icon has a red x on it and when i click it it wants to detect problems (it doesn't work). what should i do? how should I diagnose the audio? I feel like this is hardware problem as it just happened out of the blue. The audio...
I have a PC built from an Asus P5B-WiFi Delux motherboard running Windows 8 Pro with Classic Shell which has an Realtek HD audio on board sound device. I also have a Creative X-Fi Gamer sound card installed. All of these were installed and working correctly. One time I unplugged my speakers...
Thanks for anyone, who helps me :D I have "an old fashion motherboard,, with realtek's VT1818S High Definition Audio 8-Channel soundcard build in to the Asus m4a77 motherboard. Usually with W7 windows i had to install the driver from asus's website... so far when i get to the installation point it...
