Speakers are muted when microphone is plugged in
    windows 7
    Hi!
    I have a windows eight computer, and when I plug in my microphone (on my headset) my speakers are muted. I assume there is a simple sound option somewhere that does this, but I have been unable to find anything by looking around or searching google. The headset does not mute speakers on other computers when the microphones are plugged in, nor does it differ with other headsets.
    Any help would be greatly appreciated!
    Usually, PC sound systems are set up that they default to muting the speakers when a headset is plugged in, but not a microphone. The fact it does not mute when a microphone is plugged in and the feedback is a common complaint.
    Your sound card's Audio Manager (if you have one) would be the place to check for that option. e.g. I have RealTek audio and the RealTek HD Audio Manager that I have does not have an option for the microphone. It does have an option for the speakers to either mute or not mute when a headset is plugged in.
    windows 7
    I wasn't able to find any such option in my audio manager (dell audio manager), so I downloaded a RealTek codec, got the RealTek HD Audio Manager and fixed it there as you described. Thank you!
    Cool. Usually the PC vendor's drivers are the preferred, especially with a Dell. But, if it works, great.
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Dear all, I've been facing an issue with my sound lately (potentially linked to the win 8.1 update - as seems to be the case of a lot of people); I'm unable to get my sound to work, and I'm getting the following error message: "No speakers or headphones are plugged in". I've been trying out a...
Hi friends, I am using Windows 8. I am facing an issue with my sound all on a sudden. The volume icon on the task bar has a red cross on it. When I hover on that it says 'No speakers or headphones plugged in' (attachment-1). When I click on the icon I get a screen like attachment-2 which...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
I am running a Compaq CQ58 with windows 8.1 A week ago, i turned on my laptop and discovered that my sound wasnt working. I cheaked the sound menu, it told my that the speakers were not plugged in. I looked in the recording menu which told me my build in mic was not plugged in. I was able to...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
Solved Microphone in Sound & Audio
So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP :( 26062 26063 26064 26065
