Sound Applet Won't Open
    London, Ontario
    Windows 8 Pro x64
    Hi,
    The Playback Devices applet will not open.
    I have...
    1. Run the CP in God Mode to try related applets. Volume Control Options and Volume Mixer will open.
    2. Removed and refreshed all audio devices listed in the Device Manager. No errors.
    3. Run control /name Microsoft.Sound and control mmsys.cpl from an elevated Command Prompt. The Command Prompt window blinks briefly, but the applets will not open.
    4. System File Check sfc /scannow (no errors detected)
    Any suggestions?
    Running Windows 8 Pro with Media addon. Using the onboard sound from the Gigabyte motherboard. The sound plays fine on the current speakers, but I cannot change devices.
    I'm using a late model gigabyte motherboard (GA Z77X UD5H) with and i7 3770 CPU and RealTek audio.
    Exactly what do you want to change? The Sound panel is where you select the default audio playback device (you can only have one default playback device at one time). The Recording section is where you set or select the recording device, which should be Stereo Mix so that any device (e.g. mic or line in) will record or if you want to record streaming audio from the Internet.
    London, Ontario
    Windows 8 Pro x64
    I use three audio devices - headphones, stereo speakers, and HDMI audio to my television. All I need to do is change the default playback device a couple of times a day.
    This has suddenly become an issue, with the applet often not opening for me. It works sometimes, after I reboot the computer.
    I'm not "selling" anything. I mentioned Start8 and a link. There are other posts, by others not me, about start8 on the forum and on other forums. It was just a recommendation.
    I will refrain from posting on anything you post from now on.
So I've detected that my PC has been a bit slow lately, it takes longer to load webages and stuff. But this strange thing happened. I was rendering a youtube video, when Sony Vegas Pro 12 was done with the file, the software crashed, and after that my PC has been complete sh*t. Before I restarted...
Hello, I'm trying install Coreldraw, it's setup launcher is based on active web applet (ie. the ribbon on top of page). It apparently doesn't initialize. I utterly need any advice that unblocks the active content. (tried to relax active content blocking in Internet Options controlpanel but...
Solved How do I close an applet? in Software and Apps
So far, I really find Windows 8 very confusing. If I select weather in the Start screen, it opens up the weather applet (or whatever is the proper name may be). How do I then close it? I can go back to start screen but the weather applet is still running in the background. What's the proper way...
This was something I found so redundant when Windows 8 came out in the Developer Preview, PC Settings, or at the time, Control Panel. It's the little applet that is linked from the Settings UI from the charms bar. From it, you find some basic options. Sometimes it takes you to the Desktop Control...
