Speaker Problem
    Speaker Problem
    While playing a video or games or any app that has sound... the sound suddenly dissappears if it is too loud.
    At first I thought it might be the driver... so i replaced HD Audio with Conexant... but the problem still persists,
    which lead me to believe that it coild be probably the speaker's problem.
    But while tweaking aroung i found that if i quit the video or the game, the sound came back to normal.
    And also when the sound goes off,the green bar on the volume tray icon still keeps jumping up and down
    indicating sound output.Hence audio troubleshooter was of no use.
    Alnd here's the funny part, when i opened volume properties,playback devices
    (a video playing in the background where the sound had gone off),as i switched between the tabs in the dialog box
    (playbackrecording,sounds,communincation) the sound came back!
    This cannot be due to the speaker.
    I have reinstalled windows8, updated drivers and everything but no effect.
    Please tell me what to do, as i cannot see movies or play games with speaker.
    Also headfones and external speakers have no problem whatsoever.
    Maryland USA
    Does it work ok through the headphones?
    The headphone jack has a built in switch that disconnects the audio out when its connected, maybe that switch is dirty.
    Plug and unplug your headphones a few times and see if the problem goes away..
    Yes it works ok on headphones...tried doing what you told,but its still the same...can't figure out if its a hardware or software(driver )issue...installed ubuntu, and still same problem in it...does a speaker have persistence level(ludness), and can it be changed...it used to work perfectly alright...what could be the problem?
    Maryland USA
    I remember a similar problem on a friends PC, he had 2 sound cards...
    An onboard and an add-on, but disabling the onboard did not help..
    I believe it was a chipset/driver issue and on top of that we did not use a windows 7 driver, i believe we used a vista driver.
    What model is your sound card and what driver did you install?
    The windows 7 default nor the win 7 upgraded drivers were usable..
    nah me have only one sound card...but do you find which one i got?
    my driver is conexant smart audio
    pro Windows 8 64-bit
    Hi can I have your pc specs and speaker specs
    toshiba laptop
    i5 2nd gen proc
    4gb ram
    1gb nvidia 525mgt graphic card
    conexant smart audio driver...dont knw the speaker specs
    Try to refresh your computer
    Maryland USA
    you can download a small program called SPECCY which will show all your hardware on your system..
    clickl the audio icon and it will show you all of your audio devices, you can copy and paste those results here..
    in device manager when you click on sound,video,game controllers what does it say is installed? is it just generic stuff like HD audio?
    and what does audio inputs and ouputs say in device manager? at the top
Speaker Problem
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
Replace Speaker Cover in Sound & Audio
Hello, I have a Toshiba Laptop Satellite L875D-S7332. I need to replace the cover that is on top of the speakers (Speaker Cover). I want to do this myself! Can someone tell me how to do this or refer me to another information source that will teach me how to do this? Thank You, heaven5733
speaker fill windows 8? in Sound & Audio
Hi, I have an Asus G750 laptop running windows 8 and I was wondering if there is anyway I can hook up my 5.1 home theater system to my laptop and get it to put out of all the speakers? I know there was a setting in windows 7 called "speaker fill" and it would put out through all the speakers,...
As the title implies, my speaker is malfunctioning. I have no idea what to do with this problem but I have tried many things. The control panel says it is completely fine and trouble shooting says nothing. Please help me.
Hi...in my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug...
Solved External speaker fail in Sound & Audio
The internal speaker works fine, but when I plug in the external speaker, (speaker plug + USB) it seems to mute the whole system. Anyone else with the same issue?
