personalization sound
    In personalization sounds "play window start up sounds" this is grayed out cannot check or up checked I do not know what the problem is if anyone has an answer. 660 inspiron window 8.
    Maryland USA
    Are you on a system with multiple users?
    Are you on as administrator? Or is someone else the administrator? You may not have rights to change that.
    Is your sound card working?
    Are there any exclaimations in your device manager?
    Do you have a sound scheme seleted or is it set to no sound, change sound scheme and hit apply and see if the box is now available.
    Brooklyn
    I am the administrator. I changed sound schemes there are only two or 3 that is all. nothing happened. I checked device manager they were all working. my husband uses the computer he has a password. His side is the same as mine. the play windows startup sound is grayed out. thank you
    Maryland USA
    Ive disabled my sound drivers but my [ ] Play Windows Startup Sound still works, but my > Test button is grayed out, is your test button grayed out as well? or Just the Startup sound box? Im trying to duplicate your issue..
    What are the sound drivers called?
    Does it just say HIGH DEFINITION AUDIO with no brand name?
    i
    Brooklyn
    Sloe Deth, Californicatia
    That is why it is not allowing you to "test" the sounds - The actual sound drivers must be installed, active and working.
    Pull up your Control Panel-Hardware and Sounds. Go to your SOUND.
    DO you have an active device? It will have a green checkmark.
    Maryland USA
    Lorrry, Ive tried everything i can think of to replicate your problem, but no matter what I disable that checkbox always remains available to me.
    Ive even created registry changes to deny me access to the sound scheme, but no difference. It always works..
    Ive searched scores of websites including Microsoft to no avail, many have this problem going back to Win XP, but no solution.
    It looks like its just flat out not an option in your windows version, or you are denied access.
    What is your windows version? Pro or Pro Media center?
    If youre willing to try one more thing, lets start the computer in SAFE MODE WITH NETWORKING,. and tell me if its still grayed out.
    Ill keep looking, the answer is out there, its just buried..
    Brooklyn
    Harrisonburg, Va.
    This may have something to do with it.
    Or not:
    Maryland USA
    Medab1 that was the case in my instance, i was switching back and forth so much i forgot to select a sound hence the grayed out test button. Thanks for looking out..
    But in her case its the actual [play windows startup sound] box that is grayed out.. its very strange...
    Maryland USA
    Lorry, I just found a previous message from you on this forum stating that your Audio services would not start, is that still the case with your current problem or was that another computer?
    Ive disabled my audio services in my last post but that did not gray out my logon sounds box either..
    Harrisonburg, Va.
    Quote Originally Posted by Brooklyn567 View Post
    Yes.Very odd.
    Maybe somebody will provide an answer.
    EDIT--
    Running:
    in elevated (administrator) command prompt might fix it.
    It's worth a try.
    It takes a long time to run.Half an hour or maybe more.
    Restart after it finishes.
I want to change my Welcome Background but cant :mad: How to fix
I changed the location of my documents folder to just the c drive, and i cannot change it back, before i just right clicked the folder and changed it from the properties, only now i cannot see the folder only the folders i had in the documents. Is there another way to change it, i tried searching...
Solved Personalization screen in Customization
When I access the Personalization screen, from the settings menu, the background and most foreground colors are black. This seems to be the only screen that is effected. The Start and desktop are OK. Is there a way to return Win 8 back to default settings? Solved problem. NVidia driver had to...
Free downloads - Microsoft Windows A Guy
New Windows 8 Personalization Images Emerge
