usb sound box crackles and distorts with windows8
    HI I have just had to upgrade to windows 8 from XP I am using a USB Presonus audio box which is an interface for my music software program cubase6. It worked fine with XP but windows 8 is 64 bit and now all my music is going into distortion does anyone know of a setting within windows to cure this problem.
    win8.1.1 enterprise
    hi, welcome to windows 8 forums, i don't know anything about you device ,but the first thing that came to me was do you have the proper win8 drivers installed for the device ,win8 drivers in link ,not sure if your device is the same version as the one listed ,good luck
    PreSonus | AudioBox USB - Downloads
    I have a recording studio (using Sonar X2). Correct drivers is my first thought too. XP handles some audio functions differently than Vista/Win7/Win8 so different drivers are needed.
    However, does the regular PC audio also have the problem? There have been many reports of popping/crackling in regular PC audio, that can be traced (but not limited) to bad sound drivers, video drivers, wi-fi connections, etc. Make sure all your motherboard and hardware drivers have been installed with Win 8 drivers and if they are not available Vista/Win 7 drivers. Although Windows will install some drivers, the drivers from the PC Vendor (or motherboard vendor on a custom system) are the preferred drivers.
    My recording audio interfaces are a Roland Octa-Capture (primary) and an MAudio Fastrack Ultra 8R, both USB connected and both Win 8 compatible and work OK in Win 8, although Windows 7 is the OS I use with Sonar X2 (and ProTools MP9).
    thankyou
    Many Thanks for taking the time to consider and try to answer my question, my main problem is I'm not really that clued up on computers basically XP started to lock up when I changed my hard drives from sata to Solid state and it was suggested by the man who fixes my PC to upgrade to windows 8 as XP was probably not recognizing my new hardware I've just got it back from my repair bloke, so your comments are really helpful and I will pass them on to him soon. As far as I'm concerned I am only able to follow instructions like click this and open that I cant even download drivers . All I want to do is make music If I could go back to a tape machine I would but as you know it doesn't have the same flexibility for a solo artist. I wish some one would make a stand alone recording system, No upgrades, No crashing, NO frills a muso's dream, something for a time capsule that works .
    But Hey many thanks It's probably a lot warmer where you are than over here.
    Cheers Streamer.
    Let us know what your PC person says or does.
    It is obviously warmer since I'm in Florida (about 60 miles north of Tampa).
    Caperjack is in Nova Scotia. I have a "snowbird" friend that left last week for Nova Scotia (and should be home by now).
    win8.1.1 enterprise
    17 deg C here today
    not to go off topic ,but my wife's sister and husband spend the winter in Florida just got back 2 weeks ago ,not far from a place called Kissimme,they bought into a Trailer park share
    My friend lives along the coast in Hubbards (near Halifax).
    Kissimmee is a southern suburb of Orlando and adjacent to the Walt Disney World theme park complex.
    win8.1.1 enterprise
    thats about a 4.5 hrs drive from me
So, a few days ago I installed Windows 8.1 on my old Toshiba laptop after couple of years of running 7 with no problems. Today while listening to music I noticed that the sound was distorting or crackling at certain times, now a week ago the headphone jack of the computer stopped working but the...
Hello there. At first, sorry for my English. I'm polish :) Ok. Yesterday I installed (again) Windows 8 ad after month since release, I have problems with sound :/ It crackles, skipps, freezes etc :( As for me it's.. like a horror movie. Because I'm using my new laptop to gaming :/ watching...
