Sound Card Issues
    Sound Card Issues
    Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I tried plugging in my speakers, and they don't work either. I have all the latest drivers installed. Suggestions?
    Please fill in the "My System Specs". It helps for someone to try and help you.
    Done
    Which sound drivers do you have? Do you have drivers supplied by iBuyPower? If not get them and then see what happens. Generally the sound drivers from the vendor are the preferred drivers. If iBuyPower does not have drivers, check ASUS for drivers for that specific motherboard.
    Drivers are up to date for both motherboard and sound card. Going to try rolling back the sound driver. I'll post here if I have the problem again.
    Haven't had the problem again, going to go ahead and mark this as solved
Sound Card Issues
Hi, I am considering to make a Editing PC to make Dub step on, I am definitely getting a pair of Beats Studio Headphones, I wondered what will be the best sound card(I am only using 1 pair of headphones)
Sound Card not working in Sound & Audio
Sound Card Recommendations in Sound & Audio
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Sabrent SBT-SP6C sound card in Drivers & Hardware
By any chance anybody has this card and figured out how to get this card to work under Windows 8? There's no W8 driver and W7 driver doesn't work.
Hi all. I have an old TV tuner, Leadtek TV2000XP Deluxe and the WinFast PVR2 tv software. System is Windows 8 Pro. As I said, the card is old and last drivers were for Vista. But those drivers worked perfectly with Windows 7. Now in Windows 8, I instaleed the same drivers and TV Card is working...
Virtual Sound Card? in Sound & Audio
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
