laptop squeaking problem
    windows 8 pro
    my laptop produces squeaking sound whenever i play some music or video... this sound is also observed when i put the computer on a external speakers..
    the hdd is recently changed...
    what can be the problem
    Could be the mic is not muted. Mute the mic and see if that fixes it.
    windows 8 pro
    nope .... i have already tried that but no effect... and the thing is that the squeaking goes on even when i am not playing any music or sound
    by the way thanks for replying
    You haven't filled in the "My System Specs" so we don't know what hardware you have. However, since the hard drive was replaced, and I assume a complete reinstall was performed, did you install the Laptop PC Vendor's sound drivers? If not, that is a good place to start.
    windows 8 pro
    yes,,, definitely the re install of operating system was done
    i am on hp pavalion dv4 model 1506tx series laptop and the hard disk that i bought is of segate 500 gb,
    and as i installed windows 8 pro 32 bit then it itself comes with the preinstalled sound drivers so i didn't bother to install sound drivers
    Always use the vendors recommend dirvers for the mobo. The windows drivers are just generic drivers and might not work at all or completely. As firebird suggested, download your sound driver for your laptop directly from them.
    windows 8 pro
    its not just about sound... even when the sound is muted then also there is squeaking sound...
    i also just found out that my hdd test also doesn't complete.. its just struck on 58%..
    its still under warranty ,,,, do i need to replace it
    Maryland USA
    For your harddisk double click COMPUTER
    right click your windows drive (should be C:)
    properties >> tools >> CHECK
    ---------------- For your squealing ------------------------
    right click
    the speaker icon on the bottom right
    click recording devices
    double click the microphone
    click listen
    and uncheck listen to this device
    see if the echoing/squealing goes away..
HP laptop No sound problem in Sound & Audio
hey all i have a hp pavilion dv6-6150us ,,i was on youtube and suddenly the sound stopped working ,,no sound coming out from the laptop speakers ,, my on-board sound card is IDT ,,i downloaded the correct driver fro hp site ,,but it wont install ,, showing an error that the hardware detected is...
Problem with Product key on Laptop? in Windows Updates & Activation
Hello, To start things off I recently purchased a Lenovo Y500 and just can't stand the pre-installed programs and setup. The problem is there's no product key on the back of the laptop, or in the manuals I got with it. People suggested me using a keyfinder to get my Product key, but a lot...
Solved Laptop wireless problem in Network & Sharing
Hello! I have recently bought a new laptop (Asus K56C) and installed Windows 8 and also all the necessary drivers. But when I try to connect via wireless to my router I keep getting this message instantly (as if it doesn't even try to connect): "Can't connect to this network". The weird thing...
laptop squeaking problem in General Support
my laptop produces squeaking sound whenever i play some music or video... this sound is also observed when i put the computer on a external speakers.. the hdd is recently changed... what can be the problem
Problem Resetting Laptop in General Support
I have a Acer V3-551-8469 that I got semi new. Right from the start when I turned it on it wouldn't work right. It would start up with the Acer screen, then just go black. To actually see the desktop I had to sleep the computer and then wake it up. I then tried to refresh the PC but that did not...
problem waking up laptop in Performance & Maintenance
i upgraded my HP G60 laptop to windows 8 last night everything is running smooth except when i close the lid, it goes to sleep as usual but when i open it, the laptop wakes up but only shows a black screen anyone know how to fix this?
