laptop squeaking problem
ace9062
my laptop produces squeaking sound whenever i play some music or video... this sound is also observed when i put the computer on a external speakers..
the hdd is recently changed...
what can be the problem
    windows 8 pro
Could be the mic is not muted. Mute the mic and see if that fixes it.
nope .... i have already tried that but no effect... and the thing is that the squeaking goes on even when i am not playing any music or sound
by the way thanks for replying:)
    windows 8 pro
You haven't filled in the "My System Specs" so we don't know what hardware you have. However, since the hard drive was replaced, and I assume a complete reinstall was performed, did you install the Laptop PC Vendor's sound drivers? If not, that is a good place to start.
yes,,, definitely the re install of operating system was done
i am on hp pavalion dv4 model 1506tx series laptop and the hard disk that i bought is of segate 500 gb,
and as i installed windows 8 pro 32 bit then it itself comes with the preinstalled sound drivers so i didn't bother to install sound drivers
    windows 8 pro
Always use the vendors recommend dirvers for the mobo. The windows drivers are just generic drivers and might not work at all or completely. As firebird suggested, download your sound driver for your laptop directly from them.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
its not just about sound... even when the sound is muted then also there is squeaking sound...
i also just found out that my hdd test also doesn't complete.. its just struck on 58%..
its still under warranty ,,,, do i need to replace it
    windows 8 pro
For your harddisk double click COMPUTER
right click your windows drive (should be C:)
properties >> tools >> CHECK
---------------- For your squealing ------------------------
right click
the speaker icon on the bottom right
click recording devices
double click the microphone
click listen
and uncheck listen to this device
see if the echoing/squealing goes away..
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
