Acer 8930g and 5.1 audio problem
    Win 8 64bit
    Hi,
    I've installed Win 8 64bit on my Acer Aspire 8930g laptop, in January. Till recently, the 5.1 sound was ok. A couple of weeka ago, the central speaker is silent, the front left & right speakers are very low, the two back speakers and the sub are ok. I tried un-install and re-intall all audio drivers (Realtek HD audio & Nvidia digital audio) but the problem remains.
    Any help??
    Thanks.
    What type of 5.1 surround is it, make and model? Have you checked the physical connections to make sure they seated fully and no loose connections?
    Win 8 64bit
    Quote Originally Posted by bassfisher6522 View Post
    The 5.1 is from the laptop's sound system/speakers
    Are you hooking up some external speakers to it? As far as I know laptops only have 2 speakers, which can use/produce 5.1 surround speaker set up. According to your specs it confirms this..."True 5.1-channel surround sound output", under sound sub system.
    Acer Support: Aspire 8930G Series Specifications
    Win 8 64bit
    Yes, you're right. When I configure teh speakers from Playback devices/configuration, I have the 5.1 sound system, test every speaker and face the referred problem.
    Win 8 64bit
    Hi again,
    After many hours of testing, I re-installed Windows 8 64bit, clean installation. Before that I visited a computer technician in order to be sure that speakers and physical connections are ok.
    After re-installing windows, I installed the latest Realtek HD audio driver (64bit_Vista_Win8_Win8_R271) but the problem still remains. the center speaker is silent and the front left & right speakers are very low.
    I don't know what else to do. Can anyone help??
    Thanks
    I have the same problem, also clueless. It's not ideal to have 5.1 Cinematic Surround sound and no drivers to support it.
    Some help would really be appreciated.
    windows 7
    it was so annoying i was searching every forum for hours until i came with a solution
    and i just registered to answer
    the only thing you have to do is A)download the latest drivers, i downloaded the ones from 8935G for WIN7 but i think older ones should work too and B)open realtek hd manager, go to sound effects and choose "Room" voila!!!! audio works crystal clear
    Quote Originally Posted by nikokin View Post
    Hi Nikokin
    Thanks for going through the effort to register, i tried your solution but i still have the same problem, it's like not all the speakers are playing, and i cant think it to be a hardware problem. so I'm still having this issue.
    thanks again for the reply and I'm glad it worked for you
    Are you connecting your laptop to an AV Receiver with HDMI?
Page 1 of 2 12 LastLast
Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1 I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1. Once I did that, a pop-up has come up saying:...
I have an Acer V3-731. Owner's nephew somehow put W-8 Enterprise on. Received a complete set of Recovery CDs from Acer. I want to do a complete recovery, no data. First CD, "System" started and said needed UEFI The BIOS is set Security Supervisor Password-Clear Secure Boot Mode-Standard
I have an Acer 5755g with i5 vPro and 4 gigs of ram; windows 8.1 running on it. following are the problems; which made me come out and post a question over here 1. brightness can never be adjusted 2. can never connect to the WiFi i use UniBlue DriverScanner 2014 to scan and upgrade . . ....
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I canīt open it, and when I try it says that I could re-install it. But how?
Big problem to the acer unit in General Support
windows 7 upgrade to windows 8 has many problems it is not compatible to the device.. what the heck..
First I tried to change resolution from 1366x768 to 800x600 and i clicked resize to fit the display panel on Catalyst Control Center-Basic but didn't change the display. Please Help! I don't want remove win 8 after that install win 7.
