Realtek AC'97 ???
ExtremeElite
Hi! I have a bug/lag/error, I not know now...
But... When is install done, I restart it and...
"The Audio Service is not running"
Can somebody please help me?
(Windows 8 M3 Developer Preview)
    Windows 8 Customer Preview Build 8250
    ASUS X53E
    Intel Pentium B950, 2,1GHz
    4Gb
    1366x768
    750GB
Hm.... Trying Delete old device and updating : Windows Security
Not work :( Next problem: In Metro Start I not have Control Panel tile...
Installed from Windows XP Professional SP3
    ASUS X53E
    4Gb
    1366x768
    750GB
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
    24 Mbps sometimes high speed cable
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
If compatibility mode fails to run an installer there is another option.
Whenever installers run the drivers will be tucked away in the temp directory if the installer fails navigate to the temp folder sort by date. This will make locating the correct folder easier.
Once located copy the address in the explorer address bar.
Open dev manager and locate your unknown hardware when it prompts you for a location of the driver paste the location into the dialog box.
If the drivers take "then success" you have some functionality.
Note this method will not install 3rd party applications but in 88% of the times I used this method it provided hardware recognition and functionality.
    7&8
    Lennovo M55p
    E6600
    Lennovo
    8gb
    Nvidia 9500gt
