HDMI on TV no audio, poor quality image
    Madrid, Spain
    Windows 8.1 x64
    I just bought a new laptop and tried the HDMI, but there is no audio and the image is poor.
    It's an Asus X501A with Pentium 2020M Ivy Bridge and Intel HD Graphics.
    I tried changing the output resolution, to tweak the audio properties, etc.
    No success.
    Any idea?
    Thanks.
    Video and sound are separate, although both should be in the HDMI signal - IF THE PC Supports this.
    When you plug in the HDMI cable most system will change the default audio playback device to HDMI. However, it sounds like yours is not doing this. With the HDMI cable plugged in, go to the Sound Panel, Playback section. the HDMI should be set as the default Playback device.
    If you still cannot get HDMI audio, contact ASUS, since this is a new PC (or the place where you purchased it).
    As far as I know, all laptops act in this manner, I have 4 in my household, all different brands and have to do exactly what firebird has described. The same goes for the resolution, by default it uses the laptop. So in the TV settings, that's were you make those changes for input devices to change resolution there.
    Madrid, Spain
    Windows 8.1 x64
    It does change to HDMI by default, I already checked there.
    The TV is 1080p and when I look at the output resolution options for the TV in Windows, the maximum is 1366x768, which is very different. It has 1280x766 but not x720p or 1080p.
    Could this be the issue?
    I will look in the TV settings.
    Thank you very much.
    Win 8 (64) : Win 7 (64) : Vista (64) : Android JB 4.2 : iOS 6
    And just a basic troubleshooting advice that might help you too, if you have another HDMI cable, try using it also. Sometimes we've been doing some complicated and technical tweaks to our PCs only to find out that we have a faulty cable. It already happened to me before. No harm trying. Cheers!
    Madrid, Spain
    Windows 8.1 x64
    Quote Originally Posted by fourthofjuly View Post
    Thanks a lot. The cable is brand new and I bought it in case the other one was faulty, so I have tried with two and same results.
    Thank you.
    Madrid, Spain
    Windows 8.1 x64
    OK, solved.
    I did something wrong becase when I tried again to do this suggested by fireberd it went fine, the audio is on the TV and the quality seems to be HD. THANKS A LOT TO ALL.
    Graeat. Thanks for the feedback that it works.
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Whenever I go full screen on youtube it looks terrible. I have searched and searched and have no idea how to fix this. Can't even find someone with a similar problem. Blurry and 256 colours. Something similar happens to the desktop when I leave fullscreen from VLC or VirtualBox. That makes sense...
Source...
Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using? The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback....
I have alot of mp4 music videos that I would like to convert to wav or flac. Can anyone recommend the best software for doing this on windows 8?
Hi, before I state my problem I just want to clarify that this didn't occur before updating to windows 8.1. Before the update my sound would switch between the tv and the laptop speakers automatically when as I unplug and plug in my hdmi cable. Now, I put my laptop to sleep when not in use or when...
Since installing Windows 8, the audio quality in any MP4 files is distorted and echoes. This happens regardless of what player I use to view them (You Tube, iTunes, Media Player). If I play a professional video in You Tube it is OK. All other types of video are fine and all other sound output...
