What to consider when buying a Home Theater?
Wagnelles
Minas Gerais - Brazil
The same question to off-board Sound Cards. I don't have too much knowlegde in advanced sound equipament and what to consider when buying. About Home Theater, a chep one that have a good quality and immersion...
What you guys think?
    Windows 8 PRO x64
    AMD Athlon II X4 630@3.2GHz
    ASUS M4A785-M
    4GB DDR2-800 Patriot
    Sapphire Radeon HD 5770 Vapor-X
For me personally, I never buy an all in one type Home theater, rather I buy the individual components. Like a well built great quality receiver, then add the sub and then the speaker set. Not one of the cheesey things you get from say Walmart, Kmart and the likes. My personal preference is Onkyo and there are others to choose from...eg, HarmanKardan, JVC, Pioneer and so on. With this brands you can get pre assembled sets, that have matching subs and speakers with their receiver. Which is a good way to get the best bang for your buck (money). It will still be expensive but the quality can't be beat.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Ok, thanks. I got some other problems in this case, because here in Brazil we pay around 2/3 times the original prices on States due to very high taxes (We've got one of most expensive Iphone 5, 16GB model costs around 1000 dollars), so i have to watch out making a separate system... What about a 5.1 Home Theater to gaming/music?
    Windows 8 PRO x64
    ASUS M4A785-M
It's hard to be in the dark trying to build something that you don't have too much knowledge about. And you may not even tell the difference between a good and a bad sound anyway in that situation. It's ok to build your own system from individual components like what bassfisher said if you know what to do and what you are looking for. And given the cost issue that you mentioned, I guess your best option is to go and get an all-in-one system. Just make sure to go with popular brands and not local store brands or knock-off from china. Technology these days are so advanced that everything looks and sounds good. Get a branded blu-ray home theater system that fits your budget. I have a 7 year old LG hometheater system that sounds as good as they can get. I am just hoping that it will go kaput anytime soon so that I have a solid reason to get an upgrade. Hahaha.
    Win 8 (64) : Win 7 (64) : Vista (64) : Android JB 4.2 : iOS 6
    Acer AX Series & HP i-5 2400s
    Main PC - 2x Sony PS3 3D LED Displays + 1x 22" Philips; HTPC - 47" HDTV w/ 17" LCD secondary display
    Internal- 1TB on each system; 1x120GB SSD on main PC
    External (network attached)- 1x2TB Seagate backup; 1x1TB ext. storage; 1x500GB,
    http://tinyurl.com/br4uxrk
    http://tinyurl.com/cwj93pj
Well, guess I have to mention that anything i buy on Market will be sound awesome to me. Why? Let's take a look in my actual sound system:
When I'm not in home or in twilights (everybody's sleeping so i can't make noise) I use this little Nokia earphones on my PC/Smartphone:
This thing have an amazing tecnology and years of denvelopment to make the best wheezing and unpleasant noise powered by Nokia. hahaha
And in the days when i can make any noise possible here, i use these little dinossaurs to play and listen music:
What is this, i'm back to the 90's? Yeah. Actually I have a high performance PC, not the best of all, but i can play games with no problems here. But this, man, this makes any game with high sound technologies (like Battlefield 3 or Racing simulators) sounds crappy.
The best thing i [DEL]have[/DEL] had was my Guitar's amp, i used in my PC many times but now the On/Off key is damaged and i have to fix this.
So, as you can see, my sound system is veery awful, and i don't want to make a wrong choise this time, i can't afford the best thing on Market but at least I want something that will not disappoint me. That's why i'm asking for your help guys.
    Windows 8 PRO x64
    ASUS M4A785-M
Logitech surround sound speaker system…
    Win 7 & Win 8
    Gigabyte Technology Co., Ltd.
    AMD Athlon II X2 245
    Gigabyte GA-MA785GM-US2H
    4096 MB DDR2-SDRAM
    On bord
This one is a Z906?
    Windows 8 PRO x64
    ASUS M4A785-M
