Realtek Sound issues?
pathfinder68
I did search-no luck. Sound was fine yesterday-no changes by me or win update.
If I re install the realtek drivers sound is fine-as soo as I reboot the sound is gone???
Same thing everytime?
Any ideas?
Thanks
    win 8.1 pro
    Home Build
    Intel i7 3770 3.40gz
    Asus P8Z77V
    32GB
    GeFOrce GTX650 ti
    Echo Layla 3G for DAW-Realtek on MB
    Dell HD 24"
    1920 X1080
    INTEL SSD 530 OS plus 2 int Seagate HD
    Antec 650w
    IE11
    Kaspersky
Please fill in the "My System Specs" so we can better try to help you.
Has this ever worked OK? or is it a recent problem?
I do not believe my system specs will help. On board sound chip stopped working out of no where.. The reboot process seems to be disabling the service -every time. Very Strange. I can install the drivers, start the service and all ios well. Untill the next time I reboot. There is one difference actually-Windoews Defender , I turned it on but I do have real time protection shut off. Just in case I needed it to run a scan because I can update the defs.
This is extremely weird.
    win 8.1 pro
    Home Build
    Asus P8Z77V
    32GB
    GeFOrce GTX650 ti
    Dell HD 24"
    1920 X1080
    Antec 650w
    IE11
    Kaspersky
