IDT High def, low sound
    Hi ! I got some problemt with the sound on my laptop after installing Windows 8. The sound is very low when i turn it on loud, i dont do anything in the properties to the sound card. It was perfect on windows 7 and on win 8 it is low. Any help ?
    Orbiting the Moon
    Windows 10 x64
    Try to reinstall the sound driver:
    Software & Driver Downloads HP Pavilion dv6-6110so Entertainment Notebook PC | HP® Support
    If you have upgraded to Win8, the latest BIOS is also recommended.
    Update your graphic drivers as well.
    Some other drivers can also be updated as well (recommended after upgrade).
    All are found in the link above but only Win7 is available for your model. I recommend sound and BIOS from there.
    For graphics, see below.
    Get the latest ATI drivers from here:
    AMD Graphics Drivers & Software
    Quote Originally Posted by Hopachi View Post
    Sure, but win 8 is telling me that i got the ATI Radeon 7400M, and when i install the update CCC cant find anything to change
    Orbiting the Moon
    Windows 10 x64
    Yes it's strange they don't provide anything.
    See this one from HP:
    HP EliteBook 6930p Notebook PC - AMD High-Definition (HD) Graphics Driver - HP Business Support Center
    But what about sound? Look in previous link the Win7 HP driver works on Win8 as well.
    I did fix it, just needed to uninstall all the ATI GPU drivers and programs, than install it on new and reboot the pc.
    But yes, the sound card has really low sound. Dont know waht it is, but on Windows 8 the drivers are installed when it is installing.
    Orbiting the Moon
    Windows 10 x64
    Quote Originally Posted by Thee View Post
    Good. The sound must be the default driver. Look in device manager for more details, if it doesn't say IDT then it's the generic driver.
    See this thread for more info:
    Stereo Mix? Also, Windows sound driver.
    Here on my HP laptops, the IDT driver must be installed (HP site) otherwise I get weird speaker distortions and buzzings. Some other PC's are lucky enough to use the generic drivers.
    Haha, i just checked my sound card properties, i had turned on the Bass Boosed, that make the sound lower to increase the bass.
    Thanks for info on the GPU !
    Orbiting the Moon
    Windows 10 x64
    You're welcome!
Hello everybody. Before I start I just wanted to say , sorry for the bad english . So , I have read allot of forums lately , and I found out that windows 8 and windows 8.1 weakness is its latency. For me this proplem accoured like 2 months ago (before it didn't happend) , and yes I have messed...
High RAM Usage (Spotify high) in Performance & Maintenance
First off I have 8GB of RAM, and I get notifications all the time that my RAM is high, and it wants to close programs. The main program that worries me the most is Spotify is using 900MB of RAM when playing and 500MB when not playing. Why is this so high? The games I play are not even that high....
Hello, I tried so many things, running out of idea. Hope someone can assist. Updated all drivers, realtek, nvidia, amd chipset and bios. Remove everything from USB post and booted without services, disabled network drivers. When I uninstall the nvidia drivers I dont get that much latency, I...
High pitch hissing sound? in Sound & Audio
A month or two ago I purchased a desktop computer, dell vostro 200. intel dual core 2.8 with a PNY GTX260 graphics card. I haven't plugged in the earphones at all until now and I noticed this hissing sound. Its pretty loud, I'm not sure why but whenever I move the mouse a tad, there's another sound...
I have set the volume mixer to low volume for "System Sounds." However the UAC alert sound seems always to be at maximum volume, which is not tolerable. My only solution so far has been to mute System Sounds completely in the volume mixer. At least that shuts that loud UAC sound off. Is this...
