IDT High def, low sound
Thee
Hi ! I got some problemt with the sound on my laptop after installing Windows 8. The sound is very low when i turn it on loud, i dont do anything in the properties to the sound card. It was perfect on windows 7 and on win 8 it is low. Any help ?
    HP Compaq CQ-60
    Intel Celeron 2.00GHz
    3 GB DDR2
    Intel Chipset
    IDT High Definition
    1366 x 768
    Western Digital Scorpio Blue 750GB SATA.
    8-20 mbps
Try to reinstall the sound driver:
Software & Driver Downloads HP Pavilion dv6-6110so Entertainment Notebook PC | HP® Support
If you have upgraded to Win8, the latest BIOS is also recommended.
Update your graphic drivers as well.
Some other drivers can also be updated as well (recommended after upgrade).
All are found in the link above but only Win7 is available for your model. I recommend sound and BIOS from there.
For graphics, see below.
Get the latest ATI drivers from here:
AMD Graphics Drivers & Software
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Sure, but win 8 is telling me that i got the ATI Radeon 7400M, and when i install the update CCC cant find anything to change
    HP Compaq CQ-60
    3 GB DDR2
    Intel Chipset
    IDT High Definition
    1366 x 768
    8-20 mbps
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
I did fix it, just needed to uninstall all the ATI GPU drivers and programs, than install it on new and reboot the pc.
But yes, the sound card has really low sound. Dont know waht it is, but on Windows 8 the drivers are installed when it is installing.
    HP Compaq CQ-60
    3 GB DDR2
    Intel Chipset
    IDT High Definition
    1366 x 768
    8-20 mbps
Good. The sound must be the default driver. Look in device manager for more details, if it doesn't say IDT then it's the generic driver.
See this thread for more info:
http://www.eightforums.com/sound-audio/23155-stereo-mix-also-windows-sound-driver.html
Here on my HP laptops, the IDT driver must be installed (HP site) otherwise I get weird speaker distortions and buzzings. Some other PC's are lucky enough to use the generic drivers.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Haha, i just checked my sound card properties, i had turned on the Bass Boosed, that make the sound lower to increase the bass.
Thanks for info on the GPU !
    HP Compaq CQ-60
    3 GB DDR2
    Intel Chipset
    IDT High Definition
    1366 x 768
    8-20 mbps
You're welcome!
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
