Speakers not detected properly
    Windows 8 Pro x64
    I am using windows 8 pro x64 with an asus P8P67 LE motherboard and have a 5.1 sound system. I installed win 8 fresh and the audio was working fine. One time when I booted up, the audio sounded off. The sound was only coming out of the front left speaker. I did the speaker test within win 8 and the realtek menu. The front right speaker is being detected as the subwoofer and the rest are fine. It's the only speaker not working properly so it's like having two subs. I tried setting it to stereo, 2.1, speaker fill, ect... with the same results. I have not messed with wiring or software. Sometimes it would go back to normal but then do it again randomly. In the end, I reinstalled win 8 and it worked fine. Then suddenly, it happened again. The only difference this time is that it will not go back to normal by itself. It seems to be stuck on this "setting". I did do some research but I guess I didn't do it well enough because I could not find an answer that would work. Again, it worked fine in win 7 and sometimes in win8. I have checked the wires to make sure nothing has changed and that they are connected well and they are fine. I tried changing the speaker settings and speaker fill but with no results. I don't know what else to try.
    Are you using the ASUS supplied sound driver? if not, give that a shot as it has jack detection and many other features. Non-Vendor drivers may or may not work or work correctly. If you just have the default basic function Windows installed "HD Audio Codec" that is a very good reason for the flakey operation.
    ASUS RealTek audio download site:
    ASUSTeK Computer Inc. -Support- Drivers and Download P8P67 LE
    Also reseat (unplug and plug back in) all the audio cables to the PC (make sure they are in the correct jacks) and also the cables in the speaker system.
    Windows 8 Pro x64
    I did try those drivers and never used the ones supplied by windows. I used the one from the realtek website and then tried the ones from the ASUS website. I still gave them a second try but still no results. I also checked and reseated all the wiring.
    Check all the cabling internal to the speaker system. The 3 audio cables from the PC go to the bass speaker cabinet (where the power amplifiers are) and then distributed from there. Could very well be something in the speaker system and not a PC/Win 8 problem.
Solved DVD-Rom not detected in Drivers & Hardware
hi guys, new problem with windows 8, it appears that windows cannot recognize my dvd drive after i used the option in the general menu to remove everything and reinstall windows, when i check it in the device manager, it reports the dvd drive as hidden, and advice me to connect it to solve...
I recently purchased the Polk Hampden Speakers. For some reason, the manual volume control built into the speakers themselves doesn't affect the volume level. The only way I can adjust the volume is by using my computers volume control software (the little white speaker in the bottom left of...
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
rear speakers not working in Sound & Audio
all plugged in new computer drivers up to date set to quadraphonic they were working yesterday but they appear to have stopped on their own. the test speaker option worked at first but now they dont when i click the speaker icon to test on the sound playback options tab the level indicator...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
Hi there I'd like to make a suggestion here to people wanting external speakers for things like laptops etc. Go for BLUETOOTH wireless rather than USB ones since it saves using a USB port (especially on newer ultra books where the number of USB ports is limited anyway) and gets rid of messy...
