Headphones Not Working...
    Windows 8 Professional 64 Bit
    First of all my speakers DO PRODUCE sound but when I plug - in the headphones , they do not produce sound at all...Before some1 says go to r1ght click on the audio thing and properties from there to Enable it , I'll have to tell you Headphones aren't even existing there... I don't know what to do :/
    If you need anything specific about my headphones ask me
    Yes, what type of headphones? Standard analog headphones that plug into the headphone jack? USB headphones, iPhone headphones (which won't work without an adapter).
    They were working before but suddenly they stahped ... I don't know I might need to reinstall audio driver... I don't know what type they are...I just know that they have 2 cables or wtf they are , taht connect to my pc ... One is green for the sound and the other is orange for the microphone , also they have an other optional USB thing for Vibration , that I tried to switch on-off , didn't work. They are TURBO-X , and they have 3 adjustors for ON and OFF , Bass , and volume ofcourse , Thanks for your help ^_^
    First thing to try, plug the headphone into the rear GREEN speaker jack and see if it works there. If it does not work there, and the speakers work OK, the problem may be the headphone or the headphone jack.
    If it's not the headphones, before you reinstall the sound drivers, try a uninstall/reinstall of the sound using the Device Manager. Right click on the entry for the sound and then LEFT click "uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. If there was any corruption between Windows and the sound drivers this will fix that.
    Another possibility is there is a problem with the front panel headphone jack or the cabling that connects to the motherboard.
    Don't understand what exactly I have to reinstall or unistall or install from the device manager , sort of confused xD
    I'm really depressed I can't live without headphones working , because speakers quality sucks really hard ...I desperately need help...If you have teamviewer next morning connect to my pc and help me .... Please ... GOD PLEASE XD
    If anyone wants to help me via teamviewer just ask me to tell you my ID and password
    You uninstall your sound "card". You didn't fill in the full system specs so I can't give you the exact one. The most common is RealTek audio.
    This also brings to mind, are you using the correct sound driver? What do you have listed for the sound? Do you have the actual sound card, such as RealTek, IDT, etc or does it just show the generic Windows installed basic function "HD Audio Codec"? If you don't have the actual sound card driver, get that from either the PC vendor or motherboard vendor for a custom built system. The vendor's drivers are the preferred drivers.
    Good news that proly mean , hardware problems don't exist since headphones work in windows 7 in the same computer but not in 8
Page 1 of 2 12 LastLast
The program was Realtek HD. I installed it, it was trash, so I uninstalled it. Now that I've booted my PC up again, headphones don't work. Tried multiple headphones so it's definitely the drivers. Currently I've reinstalled the infernal program but would like to uninstall it while keeping audio,...
Headphones not recognized in Sound & Audio
Hi, my computer doesn't recognize my headphones. The speakers work fine, the headphones work on other devices. They used to work on this pc too, but a few hours ago my friends and I were trying to record something with a mixing table and they had to change a few things for it to work. I have no...
I upgraded to Windows 8 and now I noticed that the headphones won't work. First I followed some troubleshooting that concluded on uninstalling the audio drivers including some Intel version of the driver and then when I rebooted then the sound worked. Now it happened again and I really don't want...
I need to use StereoMix and my headphones built in mic at the same time. The problem is IF StereoMix is enabled, only the PC's internal Mic is activated. I cannot activate my headphones mic unless i disable the StereoMix device first.
No sound with headphones? in Sound & Audio
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
I have been using windows eight for about 6 months now, and suddenly the "headphone" setting for audio does not work. I tried plugging my headphones into the integrated audio in the back, and it worked from the "speakers" setting. Whenever i plug my headphones into the front audio header, any...
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
