HP Pavilion Audio Stutter Help!
    This is driving me nuts! Bought this Pavilion p6-2317c desktop a couple months ago.
    It has Win 8 x64, 8gb ram, and integrated IDT audio. It worked great out of box for a while, then I started noticing a slight break or stutter in music, whether online or on my hard drive. I tried installing fresh drivers,etc and paid attention to programs and games I had installed, but was stumped. SO I reinstalled Win 8 back fresh and everything was fixed! Now, 3 weeks later, same stutter issue!!!! I looked around here on other folks' issues and downloaded and ran the crash diagnostic tool, the results of which are attached. ANY help is greatly appreciated!!!!!!
    HP Pavilion Audio Stutter Help! Attached Files
    Orbiting the Moon
    Windows 10 x64
    Believe it or not, I also got that problem on dv6 envy.
    What I noticed here, is that it only happens with WMP, very rare on Music APP and it doesn't happen on MPC-Homecinema (Media Player Classic)... so I use the latest two until WMP gets a fix or something.
    I also messed with drivers, programs and updated all but for nothing. It's puzzling.
    But since not all music players are affected, it doesn't worry me anymore. Maybe we'll find something, a fix to that, I really hope so.
    Cheers
    Hopachi
    As it works ok, for a while, after a clean install; this suggests some added application could be the culprit. Look back over what has been installed since the last reinstall, especially those that are in the startup and start temporarily disabling them one at a time to see if it makes a difference.
    One other trick that helps, sometimes but not always, is to uninstall the sound, in the device manager, then restart the PC and when Windows starts it will detect and install the sound on a difference shared IRQ. Sound is always on a shared IRQ with a higher priority device and can be "interrupted" and cause stuttering.
    Hopachi, thanks for the rep. But, what I posted are just some suggestions on what could be the problem, not that it is the definitive answer.
    Jack
    Orbiting the Moon
    Windows 10 x64
    Jack
    No problem Jack. It's something worth testing if I get the time.
    I'm still not sure if my problem and that from OP are the same but in my case it seems to be WMP-related because all other players work fine.
    It is the same on every player or web-based app (like Slacker or Pandora). I tried uninstalling all audio from the device manager and allowing Windows to reinstall, but am listening to Slacker right now and I'm still getting that occasional slight buzz interrupt. *sigh*
    Orbiting the Moon
    Windows 10 x64
    Quote Originally Posted by modmyth View Post
    Sorry to hear that. It seems to be a quite serious issue that differs from what I have here.
    How about other programs that are in the startup, as I mentioned. Temporarily disable one at a time, those that were installed after the problem started to see if one of them is causing it. This is a good area to zero in on since it worked after the reinstall but then started doing it again later - possiblity that something installed later caused it.
***SOLVED*** Problem was an older PCI SATA I controller with a VIA chipset (NOT THE GTX 670). Replacing it with a newer PCIex1 SATA III card with a ASMedia chipset has eliminated the occasional stutter...
Sound and Video stutter. in General Support
Hi, I'm experiencing fairly regular stutters while playing either video or audio files when these are saved on my HDD. I have both a SSD and a HDD. I keep all my video and audio files on my HDD because my SSD obviously has a lot less space on it. It seems these stutters occur because the HDD...
I have an older setup (1366 i7 930) that has worked well for years with XP, Win 7, Win 8 and now running Win 8.1. About 4 months ago I started getting every kind of problem known to man: BSODs, audio skips and stutter, video hangs and blank screens (with mouse cursor still working), slow...
Audio Stutter in Sound & Audio
Hello, I've seen many threads around these forums regarding this issue but I didn't come across a "fix". My situation is the following: Every now and then, the audio of the PC stutters, its like it skips kinda when you're listening to music from a bad CD. I have the latest drivers from my...
I upgraded from Win7 to Win8 (both running the MS Media Center) and it's created a problem with music playback . It used to work fine, but now I get random stutters. Sometimes it goes 10 or 15 minutes without any problem, but often it's more frequent than that - and it's very, very annoying. The...
Freeze/lag/stutter.. maybe twice a week in Performance & Maintenance
I have Windows 7 on my 500 GB HDD which never had any issues Recently I installed Windows 8 on a new Crucial M4 SSD and I noticed issues with Windows 8 which would occur maybe twice a week until I restarted. I notice it once a website starts taking a while to load, I attempt Ctrl + Alt + Delete...
Audio Stutter?? in Sound & Audio
I have a problem with the Windows 8 preview, my audio driver and everything works fine, or so it seems. However when playing music or a game or a movie randomely sometimes often sometimes not the audio will have a slight hiccup or stutter, it does not do this right after a restart but it gets worse...
