Hi i have the following
BioStar Hi-Fi A85W Socket FM2 Motherboard - ATX, Socket FM2, AMD A85, DDR3 2400 MHz (O.C), SATA III (6Gb/s), RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCIe 2.0, CrossFireX Ready
AMD A8-Series AD560KWOHJBOX Quad-Core A8-5600K Black Edition APU - 4MB L2 Cache, 3.6GHz, Socket FM2, Radeon HD 7560D (256 Cores), Dual Graphics Ready, DirectX 11, Fan, Unlocked, Retail
Kingston HyperX Red KHX16C9B1R/4 4GB Memory Module - 1600MHz, 9-9-9, DDR3, CL9, 1.65V, Unbuffered
Toshiba HDKPC03 DT01ACA100 1TB Hard Drive - 1TB, 7200 RPM, SATA, 3.5"
Window 8 64 bit.
I recently put this computer together as a cheap media machine. Everything worked. It connected via onboard NIC to the internet, it had sound. No problems.
Then I upgraded by adding another stick of RAM. Same module 4gb. and all hell breaks loose.
I lost lost and internet. Media sound service couldn't start. Said something along the lines that found new hardward. And it wasn't communicating with my NIC card anymore.. I tried updated the drivers. No joy.
I contacted Biostar and asked for an issue. They recommend me to update drives and then reset bios setting to factory defaults. I tried that. No joy.
I then RMA's the vendor and got another mobo. Installed it and it had the same issue. No sound no internet.
Last nite I decided maybe I should just reinstall windows, but now my computer freezes on the bios screen.
I used to have a full head of hair. Please help.
Thx, Tikki.
Window 8 64 bit.
Thx, Tikki.
- WINDOWS 8
- Computer type
- PC/Desktop
- CPU
- AMD A8-Series AD560KWOHJBOX Quad-Core A8-5600K Black Edition APU - 4MB L2 Cache, 3.6GHz, Socket FM2,
- Motherboard
- BioStar Hi-Fi A85W Socket FM2 Motherboard - ATX, Socket FM2, AMD A85, DDR3 2400 MHz (O.C), SATA III
- Memory
- Kingston HyperX Red KHX16C9B1R/4 4GB Memory Module - 1600MHz, 9-9-9, DDR3, CL9, 1.65V, Unbuffered
- Browser
- CHROME
