annoying usb connect and disconnect sound
    just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall
    i seemed to find the sound in the sound settings. its the device connect/disconnect. how do i disable the sound?
    W8 Inspiron 17R W8P+MCE HTPC
    Quote Originally Posted by excaka View Post
    Click on the drop menu under sounds scroll to the top and choose (none) make sure device connect is highlighted.
    Sounds - Change - Windows 7 Help Forums
    Last edited by Brink; 17 Mar 2013 at 22:44. Reason: added tutorial link for more info
    Arkansas
    Mine does this here and there. I have noticed the cold air causes the metal in my usb ends to shrink. It is the weirdest thing. So they don't fit tight like usual.
    I had the same problem. Whenever Windows told the monitor to shut off, it would make the device disconnect-reconnect chimes every few seconds and drove me nuts. Looking into the matter further, my monitor is connected via HDMI and it was an issue of the monitor's speakers disconnecting and reconnecting. To fix it, I went in to Devices and Printers and removed the HDMI Monitor Speaker device. Problem solved, since I don't use the monitor's speakers anyhow.
    Windows 7
    you will have to just disable the default device connect sound in windows.
    Step by step
    Disable USB connect sound in windows | Maine Geeks - Local Computer Repair Services
    Windows 7 ultimate 64bit
    I have the exact same issue, but in win 7. It started a few weeks ago right after i upgraded to 2x 120GB ssd's in raid 0, the sounds would come randomly, and after a while, it stopped. But yesterday when i deactivated sli, i got a bluescreen of unknown reason, and after that i now get those sounds continuously when the screens go dark (got 4 screens connected, 3x dvi-d and DP-HDMI adapter)
Hello everybody. Before I start I just wanted to say , sorry for the bad english . So , I have read allot of forums lately , and I found out that windows 8 and windows 8.1 weakness is its latency. For me this proplem accoured like 2 months ago (before it didn't happend) , and yes I have messed...
Hi all, I have read quite many posts so far regarding this issue in Windows 8. It Looks like they have overlooked the Sound skipping problem during playback on different programs and codecs. Whenever one uses Media Player, Spotify or any other audio programs the Sound skipps and crackles. It comes...
Annoying sound pannel popup in Sound & Audio
Hi, anyone having this problem ? Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :( Is there a solution please ?
How to Connect To or Disconnect from a Wireless Network in Windows 8 and 8.1 If you have a laptop or a PC with a wireless network adapter, you can see a list of available wireless networks in your area, and then connect to one of those networks. The wireless networks will only appear if your...
Hi, I have an Acer 5750g 8gb of ram i5 core laptop and it has always had like a 'clicking' sound to it. After reading up i read that many people get this from their hard drives in a suspend or hibernate state and it is just the hard drive making this noise and not to worry about but the noise...
Solved connect/disconnect from internet in Network & Sharing
Silly question probably, but what is the best routine for going offline and then to reconnect when appropriate. I'm going all round the houses at the minute... :think:
