Videos and audio stuttering with mouse
    Hello,
    When I watch youtube videos, or videos in Windows Media Player Classic my audio randomly stutters. This also causes my mouse to stutter and skip and move slowly.
    I have tried to fix this issue for awhile. However still no solution.
    Any ideas or tips would be great, Thanks
    Can you fill in the "My System Specs". Without that we can't even offer a guess.
    Thanks, Just filled it in. It is just a pain in my arse. Its not unusable but randomly stutters and lags.
    Well, with the system you have that should not be happening. I just built a second system using an ASUS P8 Z77-V LE Plus motherboard, an i5 3550 and 8 GB of GSkill Ripsaw memory (and . I'm, initially, using the built in Intel HD Video not a separate video card.
    The first thing, do you have the correct sound driver installed? The driver from ASUS is the preferred. Second is the Intel motherboard chipset drivers. They can be downloaded from ASUS or Intel.
    Other than those two drivers, there shouldn't be any IRQ interrupt problems. Does this happen with on-line video/audio only? or does it also happen with video or audio that you already have on the PC hard drive or if you play a commercial audio CD? Just trying to isolate it to where/what.
    Also make sure all your flash players are up to date. What type of mouse do you have and does it require a separate driver/firmware/software install?
    I have the updated Sound drivers and chipset drivers from ASUS. I have the installed drivers for my mouse. The flash player I have installed is current.
    The videos that cause the stutter are online as well as with windows media player classic.
    Hope this helps you help me
    Thanks
    Is it ONLY videos that cause this? I'm still a bit confused, I see you mention on-line videos. Does this also mean videos that you have on the PC's hard drive (where did they come from?) also do this. Does a commercial Video DVD also cause this? Does just playing audio cause this?
    If its ONLY videos that cause this, for testing, remove the GTX670 video card and use the built in CPU video and see if that also causes the problem.
    I have videos downloaded on hdd and they stutter when played. Then youtube videos and other streams cause the lag as well. I had the issue with a commercial dvd in the drive. But the issue was much less with he dvd. Only happened twice in a few tv episodes.
    For uninstalling and trying withouht graphics card... Can I just unplug the power? Or do I physically need to remove the card?
    I had my task manager open and when the stuter happens the CPU load from System goes up much higher. Generally it is at less than .5%. But with the stutter it goes up to just below 10%. No idea what this means or how to fix this but you might know.
    When I am installing the chipset drivers. It does it nearly instantly... However the driver is 247mb when ziped. Is this an error? I checked with my device manager and states the driver is only at 6.2.9200.16451, which is from 2009. However I cannot install the new one now mater what I try. But then when I go to the intel driver scanner tool it says that it is updated and correct.
    I don't think just unplugging the PCIe power plug will work, but you can try that. If not, then you will have to physcially remove the video card, to test the CPU video.
tried to play any music in itunes and no audio, music bar line never leaves the far left end. tried to watch video and no audio, video itself is fine but the sound disappeared no clue how or why. tried to raise the volume meter for the audio of windows itself and the audio is ok. and also my...
Solved stuttering mouse and lag help in Performance & Maintenance
So i have done everything i can think of to fix this even re-installing mouse software, but for some reason not all the time i will get mouse lag and stutter were i will move the mouse but the pointer barely moves on my screen, is there a fix for this? someone help please.
Audio/Visual Stuttering in Sound & Audio
I have been experiencing stuttering both audio and video. This occurs after the computer has been running for two days (hibernating at night). For the first day it works perfectly, youtube, MPC, etc work flawlessly. Then towards the end of the second day, stuttering, with no apparent cause. ...
Hi geeks. For sometime now, can't say exactly when it started, all Flash videos have a strange startup delay. Videos buffer fast, no complaints, audio starts immediately but the video hangs there up to 7 - 8 seconds showing the first frame and then after this delay, jumps forward to catch the...
Hi, I'm Locky, I am usually a pretty competent computer user, and have never had to post on a forum for help, but I am by no means skilled, thus I came here seeking help. I'll give you as much detail as I can, I am very much in need of help. I have been experiencing a problem the last few...
Video, Audio and mouse skipping or stuttering in Performance & Maintenance
Hey guys, I just did a fresh install of windows 8 on my system. Specs are Win 8 intel 3570k 8 gig 1600mhz ram Asus p8z77 - pro
after about 10 to 20 minutes of use the whole computer begins to stutter, audio video... the mouse skips around and it is almost unusable just upgraded from 7 ultimate to 8 pro, and ive included the diagnostics what in the world is causing this?
