Can somebody help me diagnose sound problems?
    Hi
    I'm using Windows 8 with the Media Centre plug-in.
    My problem: After watching live TV (Satellite using TBS 6981 card) for a few minutes, the sound starts to stutter and gradually gets worse until there is no sound. If I simply go up or down a channel, the sound is fine, then it starts to stutter again after a few minutes.
    I have the latest drivers installed for the TBS card, the HD on board sound and the motherboard.
    Other things like Spotify or iPlayer work faultlessly.
    Where do I start my diagnosis?
    HELP!
    Since everything else works OK, it has to be an issue with the Satellite card or reception.
    Well I guess that is the logical answer.
    I didn't mean it to be a wise guy answer. It appears that its not a PC sound hardware or driver problem and its working correctly and just the application, in this case the Satellite card/software/configuration is causing the problem.
    It could even be the Satellite receiver or transmission that is causing it.
    No, it's fine. I feel a bit silly for not coming to the same conclusion. Sherlock, I am not.
Hello. Firstly forgive me but although my dads pc is on vista currently I trust your knowledge and input on an issue that can really occur across multiple platforms.. Now the issue he had before was an error within chrome and IE claiming it was unable to connect to proxy server. Anyway that was...
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Hi Had to replace my Asus laptop battery and the had a problem with windows 8.1 upgrade not starting goes to automatic repair then diagnose then unable to repair then start again. Put in windows 8 upgrade DVD but won't boot it , goes on automatic repair roundabout . Tried repair gives a...
8.1 sound problems in Sound & Audio
Updated to 8.1 and had the dolby problem like everyone. I am not that good with these new fangled machines but how do I fix this problem. The sound is now terrible and I have it all the way to the top and can barely hear anything. Is there a fix that is available or do I need to go back to regular...
Solved Problems with Sound in Sound & Audio
Okay, starting from the more recent beginning, I decided to upgrade my computer. I installed a new gpu and cpu successfully, but failed to correctly install the power supply. While trying to start the power supply, it shorted and fried my hard drive. After a few painful weeks with best buy, they...
