New here, audio (specifically mic issues)
furn355
Hi as the title suggested I am new here.
Usually I like to contribute before asking too many questions but I come in a time of need.
I will explain my issue:
I am using a Windows 8 (64bit) Samsung NP350V5C-A08UK.
Yesterday I plugged in a pair of apple headphones(with the mic) straight into the mic line in. They worked after a little bit of tweaking (as a microphone). Today they are no longer detected and I cant seem to find the same fix as I applied yesterday.
Notes -
Yes the mic works, tested it with my iPhone. The onboard mic works too. (Not an option to use this however)
If anybody has any potential fixes please let me know:)
Hi furn355 and welcome to Eight Forums!
Unfortunetly i think it's hard to solve your problems with additional information so could you please tell me:
Have you checked the Sound Settings? Is Volume pulled up? Is it set to default?
    Windows 8 Pro x64
    Self Builded PC
    Intel Core i7-3770 @ 3,9 GHz
    MSI B75HM-E33
    2x8 GB DDR3-1866
    EVGA GeForce GTX 550 Ti 2GB
    Integrated
    LG 22" x 2
    2560 x 1440
    Samsung 840 SSD 120GB,
    Seagate 1,5TB,
    Local NAS 2 TB
    Thermaltke 600W
    Coolermaster HAF 95
    Normal 3 x Fan
    Gaming for $10
    MSI Gaming
    25 Mbps / 4 Mpbs
    First time i builded it i have put the cpu wrong and messed up socket :/. Manufacturer send it me back after i thought it's broken...
Do you have a System Restore point back to when they did work?
I did a google search but did not come up with drivers for this model. But, are you using the correct Samsung supplied sound driver? or just the generic basic function Windows installed "HD Audio Codec". If not using the correct Samsung sound driver, that would be a good place to start.
Just did a system restore, still doesnt find it.
Still not detecting in the sound part of the control panel when i have plugged a device in too the line in port
If it helps it isnt showing any line in on my sound control panel although it shows i have plugged something in:
see attached screenshot
Screenshot by Lightshot
In the Recording Panel, RIGHT click in a blank area and then LEFT click to select show disabled and disconnected devices. Then see if it shows up.
If not, go to the Device Manager, RIGHT click on the Realtek entry and then LEFT click "uninstall" (Do not uninstall the drivers, just the device). Restart the PC and when Windows starts it will detect and reinstall the sound. If there were any corruptions in Windows for the sound this will fix it.
Exactly what type of Apple headphone/mic do you have? I have an iPhone5 and the mic/headphone that came with the iPhone will not work with a PC.
I am using iPhone 4 headphones/mic combo, and like I said, i did get them working for one brief recording
Should I be concerned with it not showing the line in option?
I think the iPhone4 headphone/mic is different from the newer model that comes with an iPhone5.
According to the description on the Apple site it has a four conductor 3.5mm plug. It doesn't say what is on different sections of the plug. It may not be compatible and it working was a fluke.
Regular "PC" microphones are "condenser" types that have the audio signal on the tip and the "ring" provides the 5 VDC that is needed by the condenser mic to work. I don't think that is the case with iPhone mic's.
I don't know about the line in. Some Laptops have a combo mic/line in jack and it auto senses which is plugged in. I don't know what your Laptop has or what has been provided in the PC vendor's RealTek sound driver. The RealTek drivers are customized by the PC vendor for their specific application.
