Audio very low
Guardiann
Hello,
As seen in the title, my audio in windows 8 is like 15 % of what it would normally be. Tried all sorts of fixes (also on this forum), reinstalled drivers and such. Nothing helped (and yes, the audio slider in the right hand corner is all the way up).
I use a Tritton 5.1 headset, stereo mode. This has worked fine for more than 9 months now. But a week ago my sound was suddenly lower, so I put my headset volume a bit higher. The next day, the sound was lower again, but now I can't slide my headset volume higher... The weird thing is, when I use my Logitech 2.0 speakers nothing is wrong with the sound, it's just 100%.
Hope you guys are able to help me, because gaming with my speakers on all the time, doesn't work for me.
Bye,
Guardiann.
    Windows 8.1 Pro 64-Bit
    MS-7816
    Intel Core i5 4670 @3.4 Ghz
    MSI Z87-G43
    Corsair Vengeance 8GB CMZ8GX3M2A16009B
    Sapphire R9 280X 3GB DDR5 OC VAPOR-X
    1. Samsung idk name 1920x1080 2. Eizo 1280x1024
    Seagate Barracuda 7200
    Corsair CX750M
    Cooler Master CM 690 III Window
    It'll come
    HP standard one
    Logitech G500
    5 MB/S
    Antivirus is for noobs
You can test the headphone jack by plugging in the Logitech speakers into the headphone jack (I assume the speakers have a 3.5mm plug). Or you can plug the headphones into the GREEN speaker jack on the rear of the PC to see if the headphone audio is OK or low, that will tell you if the headphone is the problem and not the PC.,
Ok, so I did this, and the logitech speakers have normal audio in the jack I use for my headphone(the rear one). Also, I tested the headphone in the jack where I had my speakers plugged in (the front one), still the volume is really low.
So, the conclusion is that my headset is the problem? And if so, it somehow randomly broke?
    MS-7816
    MSI Z87-G43
    Corsair CX750M
    It'll come
    HP standard one
    Logitech G500
    5 MB/S
Headphones will go bad, just like other electronic parts. If they are still under warranty contact the manufacturer.
Ok, thanks.
    MS-7816
    MSI Z87-G43
    Corsair CX750M
    It'll come
    HP standard one
    Logitech G500
    5 MB/S
