How to get FFdshow audio decoder to work with WMP12?
    Windows 8 Enterprise, Lubuntu 12.10
    Can someone show me how to configure FFdshow to work with WMP12
    win8.1.1 enterprise
    hi, not sure never used it ,but ,since it hasn't been updated since 2006 ,its likely that it will not work with mwp 12
    ffdshow - Wikipedia, the free encyclopedia
    Germany/Florida
    Vista and Win7
    As was said, this is an old Codec pack and is liable to give you trouble. Uninstall it asap - with Revo advanced option.
    What codec is not working and what were you actually looking for.
    San Jose - California
    Quote Originally Posted by whs View Post
    Agree. If you can avoid installing any kind of codec packs. You can use alternative players such as:
    1. Download VLC Media Player | Freedownloads.us.com
    2. KMPMedia
    They have their own built in codecs and will play all the popular video formats
    It does work. I was able to get it to play mkv files in WMP 12.
    My problem is that I really do want to stick with WMP 12 but I can't work out a way to shows srt files for my subs.
    Any ideas? I understand that you can do it with WMP 11 but that doesn't appear to work on Windows 8. I removed WMP 12 but it still didn't work.
    Looking forward to hearing your replies.
    Greg
    Germany/Florida
    Vista and Win7
    Why don't you convert the files that don't work to another format.
Title says it all. I don't care if the "Now Playing" window shows the album cover as 200x200. All I want is to make it look sharp and not blurry. My mp3s have embedded 1000x1000 album covers. (The problem persisted even when they had 200x200, 300x300 etc images) ...
Hi, When I am trying to play a media file (or just open WMP12) it goes to the welcome screen. No matter what I choose after It cannot finish the setup process and always comes back to the welcome screen. I've tried to remove, clean & compact the registry and install it back using programs...
An automatic update occured, and a blank box popped up continuously(Titled: C:/swsetup/sp59654/IDTSetup.exe) I was using my USB headset during that update, then all of a sudden they stop working and only my speakers were working, and no devices were being shown under playback devices nor under...
I hae a dell m1710, installed win8 rtm on it. In win 7 i have 2 options of digital audio out: 1. Turtle Beach Audio Advantage Micro usb with optical S/PDIF out 2. Dell composite video adapter with digital coax out. Sigmatel high definition audio codec In win 8 i tried first the Audio...
Hi all, Ever since I have downloaded Win8 Build 8250 my audio has gone weird. If I pause a song in iTunes or a video for more than about 4 minutes then when I try to replay the song there is no audio. The only way to get the audio back is to restart the program. I have encountered the problem in...
Hi all, I have tried the drivers from RealTek and also the drivers from MSI. (My motherboard is MSI P35 Platinum). Driver installation / removal always proceeds without any errors. But the Audio Service just can't start. In some places, the RealTek device reports status "working properly"....
